I think it is very smart to re-check after a short drive. You may be lucky to catch an oops before tragedy strikes or the very least, an inopportune time to change your drawers🤣
I hope those who do use a hammer/mallet (& I know there are a few on this forum) heed the advice, tips & or warnings as to why it is a bad idea. Learn to operate the equipment As intended...
Regarding a check before driving...we always have a check around the camper and the truck... even when leaving our driveway. Although we are "novices" unlike many of you...we certainly would not use a hammer or mallet on the hitch! I sense some folks have jumped to some conclusions ...both of us are very vigilent about safety. In fact, it is because of that this both of us and our dog remained safe. We turned to the forum to hopefully gain some feed back. For those that have replied without jumping to conclusions...your comments have been greatly appreciated. Before heading back...all we want is to be safe!
@Om3, I have been following this discussion closely, as a fellow T@B owner, as a friend of many here, and as an Administrator. Please trust that I would intervene if someone was out of line. Everyone is fine, no one is blaming anyone. Your situation is a learning experience for all of us.
Verna, Columbus, IN 2021 T@B 320S Boondock “The T@B” Towed by a white 2019 Ford F-150 4x4 Supercab, 3.5L V6 Ecoboost “The Truck”
@SAM, I just discovered it in edit on the photos on the iPhone and iPad. It’s looks better if you use a stylus. I’ll show you when we see each other, if you can’t figure it out. There are different thicknesses of pens to use, too.
Good Morning...does anyone know that maker of the coupler that is on the 2018 T@B400? Visited an RV dealer in Fairbanks this AM and they asked the maker in order to check if they have one in stock.
Check out the second video above that Marceline attached. It is an Atwood coupler. If it is the same as your 400, then it is an Atwood. Can you take a picture of your coupler?
Just to be clear - I'm not sure that the coupler in the video is the exact coupler on a T@B 400. I was just trying to find good videos of this style of coupler that show how the mechanism works (and what can go wrong).
San Francisco Bay Area 2013 CS-S us@gi Battered but trusty 3.5l V6 Hyundai Santa Fe 2015 Toyota Tacoma PreRunner Double Cab
My learning experience was the hitch popped off after moving 3 feet, still in the trailer storage yard. I would have bet really good money the hitch was fully engage, but it was not. So I was very, very lucky. Like two others mentioned above, after engaging the hitch I jack the trailer up to see if the hitch pulls the tow vehicle up, if it does more than a few inches (just look at the gap between the tow vehicle rear wheel and the fender) then I KNOW the hitch is engaged. I check it every hookup.
Again...thnks all for the comments and support! Unfortunately, most of Fairbanks is shut down due to the fourth. Hope to see someone that was recommended tomorrow AM.
@Om3, you remind me of my old 35mm film camera which I bought in 1978 - it's an Olympus OM3. Wondering if you ever got any photos of the damage to your tongue, jack, or tires. Would be interesting to see.
-Brian in Chester, Virginia TV: 2005 Toyota Sienna LE (3.3L V6) RV: 2018 T@B 320S, >100 mods
To be clear, the hitch in the picture posted by @WannaBeMini is not latched. If you take off towing like that there is a very real chance that you'll lose the trailer...always make sure that the latch is down. There have been previous posts about how the hitch works and tricks for making sure that you hook up correctly.
WRT the ball size...the hitch balls are always marked on the top. This hitch needs a 2 inch hitch ball... it will drop over a 1 7/8 and it will latch but it will not have correct engagement and could bounce off...
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
2019 T@B 400 BL
Om3’s tongue came totally off the ball that is screwed to the drawbar. It had nothing to do with the hitch.
have one in stock.
Adventures: 51 Nights: 322 Towing Miles 41,200+
2018 T@B 400 - "T@KO T@B"
CincyKid
Cincinnati, OH
