During my recent factory visit to nuCamp in Sugarcreek, Ohio to take care of two minor warranty repairs I was fortunate enough to get a factory tour, which they appear happy to provide. Normally the tour is conducted from a second floor walkway that overlooks the factory floor, which means you can't get close to the trailer builds to take photos. Fortunately the factory was on cleanup prior to the 4th of July week shutdown and no builds were in progress. As such John, my tour guide, was nice enough to allow me to take photos of in-process T@B 320 trailers from the factory floor, which I share with you below to allow you to see where electrical wires and fluid tubes are located. Sorry T@G and T@B400 owners, I am a relatively new owner of a T@B 320S Boondock so I only requested to photograph these in-process trailers. I know these photos are not complete showing all systems, but they may help in your efforts. I make no guarantees as to the accuracy of these images for your trailer, use at your own risk.
Photo 1 - View of T@B 320 Assembly Line
Photo 2 - Shows the Difference in Roof Construction for the Clamshell for the outdoors kitchen (left) and internal kitchen (right)
Photo 3- Trailer Body Prior to Adding Walls, Some Cutouts for Piping Added (this layer has a wood strip along the front and back edges)
Photo 4 - Wall Details (Believe Inner Wall is on Left)
Photo 5 - Front Isometric View Showing 320 Forward Cabinet Walls and Bathroom (Blank Tank below)
Photo 6 - Front View Showing Cabinet Construction
Photo 7 - Front View Showing Refrigerator Drip Pan Installed
Photo 8 - View (Blurry) Black Tank Details and Sewer Valves
Photo 9 - View from Rear Showing Floor Box Structures
Photo 10 - Alde Floor Cabinet and White Hoses for External Shower (black corrugated hoses upfront appear to be temporary wood surface protection); Red & Blue shower water tubing visible
Photo 11 - Air Conditioner Cabinet Structure (Outside Wall Looking In)
Photo 12 - Alde Fluid Tank (located to be highest spot in Alde fluid system) - Access to Tank on a finished trailer is from Wood Panel that slides forward on the rail closest to viewer after removing 2 screws; clear Adle tank vent tube visible; clear speaker wiring visible
Photo 13 - View of Radiator Fins for Refrigerator (Viewed from Outside Wall Access Looking In, Drip Pan is Below)
Photo 14 - View of Space Under Propane Stove
Photo 15 - View of Sink Cabinet (left upper), Bathroom Cabinet (right) showing wiring and hose arrangements (silver box below sink is un-installed Jensen System)
Photo 16 - View of Alde with Electrical Wiring (aft) and Wiring Runs in Wheel Well Cabinet (forward)
Photo 17 - Another View of External Shower Connections and Some Alde Tubing
Photo 18 - View of Alde System Heat Fins Behind Lower Rear Cabinet
Photo 19 - View of Second Alde Heat Fins in Under Seat Cabinet Near Trailer Door
Photo 20 - View of Toilet Drain and Shower Drain Pan
Photo 21 - View that Shows the T@G and T@B Diamondplate Boxes are Different in some way (perhaps pre-drilled holes)
I don't suppose you have any shots of the steel framing under the floor?
Cleveland, Ohio
2018 Ford F150 XLT pulling a 2020 T@B 400
LIFE IS GOOD!
CincyKid
Cincinnati, OH
In that shot of the bare trailer with nothing but a flat platform on wheels, is that the floor or subflooring? It looks like it's mostly foam inside, but how could that be rigid enough? It would sure provide a great vapor barrier though, as long as all holes were well caulked. Must have been a very interesting tour.
https://tab-rv.vanillacommunity.com/discussion/comment/92831#Comment_92831
CincyKid
Cincinnati, OH
CincyKid
Cincinnati, OH
Anyway, thanks! 👍
CincyKid
Cincinnati, OH
CincyKid
Cincinnati, OH
CincyKid
Cincinnati, OH
Thank you for taking the time to help us get a better understanding of the process.
Paul's videos include 2019 models of: 1-General, 2-400, 3-320, 4-320S Boondock Edge. There are also two on T@Gs, specifically a Max line video and a Max Boondock Edge. I am not a customer of his, as I live on the other side of the country. Just sharing what I found. Starting here: https://www.youtube.com/watch?v=6QKAQv4UbaU
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
.. and wondered if the white semi-cylinder across the tongue might be reserving a spot for a sewer hose storage tube. I wonder if that is that an option now?
2019 T@B 400 BL
