On two outings I've faced setting up a
T@B 320 on soft surfaces.
One was deep loose gravel at a private RV park the other well watered
front yard grass. For both situations side-2-side leveling with
blocks was needed which then limited wheel chock placement to the
'uphill' wheel. Each time when disconnecting the
T@B coupler from
the TV the
T@B rotated toward the downhill side rolling off the wheel
block and pushing the wheel chocks deep into the soft surface. Plus
the tongue jack wheel dug a trench as the
T@B rotated.
My solution was try and try again. Each time moving the
T@B some
attempting to find firmer ground for the wheel chock side. This
cycle of do-overs was exhausting and a bit embarrassing.
So
how do the more expert
T@Bbers out there handle
Parking / Set-up on
Soft Surfaces ?
Blocks
are: various
thickness wood boards and the lego levers
Chocks
are one
pair of yellow plastic Camco # 44412 8x5x4 inch
'18
320 S,
pitched axle, 3020HE; PNW based
I suppose if I had mushy ground, I'd use the Lynx levelers under both wheels, one being higher if necessary. Plus I have the Lynx caps for under the stabilizers. (I don't have boards).
Sold 2023 Tab 400
Sold 2018 T@B 320S
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Glad you could find the "lego" type chock. I put it on the front like your picture, then pull forward. It gives me some comfort I don't pull too far. I put the Trimax Wheel Chock on that same wheel on the back, so I don't think it will move once on. With all these chocks, I have a variety of options and now you will too!
Sold 2023 Tab 400
Sold 2018 T@B 320S
Tip: When on level ground, kick the chocks behind the wheel on each side, then back up the TV slightly. Then there isn't a chance the coupler isn't pulling backwards on the inside jaws and won't release when you try to unhitch. Makes unhitching much easier!
