I want to use a generator in FL and need to know if Alde Heater can be turned off. I assume the system works thru the Thermostat automatically and does not draw power if set low enough, however, to be sure would it be best to turn it OFF somehow? How do I turn If OFF? Is this harmful?
0 ·
https://www.alde.us/documents/3/v-3010-60-rev-1487-us-can.pdf
P.S. Not sure about the 400. Maybe V can check in her down time (yeah, right), to see if there's that 110V plug for the Alde.
But, I would caution unplugging from the 110V unless you turn the display or analog control off first. You will have fewer blown fuses if you always turn the display off before connecting or disconnecting power.
I agree with @ScottG that this will save very little energy, whether 12V or 110V.
