The chains that attach the trailer to my car dragged on the ground for too long and were damaged. I called uHaul and a place that attaches bike racks, but neither do this. It's actually a pretty easy process, but I can't do it myself because I need a chain cutter and then maybe a solder or however they attach the chains.
Has anyone ever had this done and what kind of place was it? Also, if it's easier I can buy a piece of equipment or two and do it myself.
Those are just fine. I don't understand? The tongue is one tenth of that. It just has to cradle the tongue while the emergency brake pull stops the trailer, right? Or do I have that wrong?
Adventures: 58 Nights: 405 Towing Miles 50,180
That Purdue University guide that Larry shared with us just keeps on giving. Every time I peruse it, I think of him.
MuttonChops said:
TV 2007 F150
You miss nothing. That chain was just a scrap I put together for the demonstration photo
TV 2007 F150
Storytime:
I picked up the toy hauler and happily left the dealership after a wonderful double walk-thru and fun time at the dealer because it was right before Xmas and no one else was in the dealership except employees.
So I stop at a grocery store to put on extension mirrors (mid-sized truck at the time). Quick check of everything - focused on turn signals and lights, and making sure the propane was turned off. People must have thought I was a nutcase because I was backing up and going to other parking spaces in the back of the big lot and backing up again. Fast forward to the gas station where I learned not to take a quick right turn because the trailer turns at the same time. Ooops. Almost took out a pillion. Well, after getting gasoline and trying to look nonchalant, I glanced at the chains. I about wet myself. I had two perfectly good 8000# rated links on my hitch and the tech put the emergency brake controller cable on a keychain carabiner. That thing wouldn't be strong enough to handle a strong wind! Quickly corrected and even unwound it from the chains. Then I wondered if the tech was into the eggnog too early in the morning and then where was my brain when I did that initial check with the lights! Ugh. All ended well. Lesson learned. Never assume. Check everything.
I swear I have had, when renting trailers, Uhaul folks twist chains to correct length...presume their risk management folks have not read the Purdue U guide.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
