Dewinterizing today and found a water leak. Aargh! I opened the bench and pulled the shower access panel off and all the plastic pipes and joints are intact and dry. It looks like water is leaking from under the shower pan.
What might the problem be, and how can I find it? We are due to leave for a trip on Friday.
0 ·
Also, look under your driver’s side bench and around the Alde pipes.
Just because the water is under the shower doesn’t mean the leak is right there.
I have no idea what this check valve thing is - does anyone who might be reading my tale of woe know?
https://tab-rv.vanillacommunity.com/discussion/7451/city-water-fresh-water-tank-cross-connect
Is there any possibility that the water you are seeing is condensation?
The only other thing I could think of, based upon your finding of no water pipes around water lines, etc., is water backing up to the shower from the gray water holding tank. However, I assume that tank is empty since you are de-winterizing.
Hope you figure it out............very curious about what you ultimately find. (Greg)
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I taped some paper towels to a flexible rod and poked it down in the compartment where the water pump is and everything was dry down inside there.
This ain’t condensation.
https://tab-rv.vanillacommunity.com/discussion/6090/teaser-alert-what-does-it-look-like-under-your-shower-repair-completed
Not sure what kind of connection is behind the fresh water feed for the toilet.
I agree with Scott (except that you may not be able to reach the city water inlet fitting unless you have plyers or very long arms. It's directly under the fresh water inlet, which also makes it hard to reach. I would suspect the city water inlet valve is loose on the inside. I posted photos of this leaky part recently, which I fixed by tightening the nut by reaching down behind the toilet with vicegrips - not easy & long arms would have helped. My main symptom was water leaking from under the front end, but if yours was nose-high then it could run towards the back.
http://tabforum.nucamprv.com/#/discussion/8617/fresh-water-leak-help-needed-fixed/p1
PS: what you might think is the bottom of the compartment below the water pump is probably the top of the black water tank which extends forward near the front wall. There is only one narrow space between the tank & the driver side wall where the actual floor is exposed, and it's a small area in the corner, a few inches at most. That is where water would fall from a leaky city water port. From there it can leak out through the floor to the ground or run back beside the shower to the rear, depending on tilt. We generally keep our nose slightly down, so ours leaked at the front edges of the floor.
I 'just happened' to check the kitchen sink supplies last fall, and they were quite loose. Not leaking (yet), thank goodness.
So I found a video on YouTube about replacing the check valve and learned that it is exposed on the back side of the toilet. If that were leaking I would think it would feel wet to the touch and would drip behind the toilet onto the shower floor. My shower floor is dry. The water seems to be coming from UNDER the shower pan. Am I understanding this correctly?
When the valve on our toilet froze and cracked, it leaked into the shower.
edit: I confess, I don't know what a 'check valve' would be doing in the toilet though. Do you mean the supply valve, or do you mean the large drain/flush valve in the bowl?
City water valve seems to be a fairly common leak versus one of the many Pex tubing fittings, which are very sturdy & would also be more difficult to fix because you need more space for working with a big pex wrench & two hands.
Here's one view from way down in the front driver side corner near floor with my 180° camera..
Water pump connection is at top left corner & trailer floor corner at bottom right. The water lines & wiring conduit pipe in bottom half are going to the rear through the space below the white shower ledge seen above them. Immediately above them at right is the suspect black collar screwed onto the city water connection check valve, located directly below the large corrugated fresh water inlet tubing. The side of the black tank is just to left of the lowest blue water line.
There was some water in the lines from yesterday’s misadventure. With the lines pressurized I did NOT see any water coming out from under the shower pan like yesterday.
There is one other thing that I’m thinking about and want to run it by my advisors here. I know from watching the video above that there is a seal on the underside of the toilet that seals it to the black tank. If that seal were cracked or damaged, is it possible that water might leak onto the black tank and run out under the shower pan?
So we assumed maybe the toilet was the culprit and decided to sanitize the fresh water tank. Shortly after turning the pump on and starting to run the sink faucet, my husband yelled that he was seeing a leak under the trailer. So I stuck my hand back behind the toilet and sure enough there was water dripping from around the city water inlet. We did not have a hose attached to the city water.
Any ideas for me? We unscrewed the city water inlet on the outside of the trailer to see if we could see where the water was coming from but the hose on the back is tight and it would only come out about 1/4 inch.
How on earth does anyone fix anything in that area down behind the toilet?
https://tab-rv.vanillacommunity.com/discussion/8617/fresh-water-leak-help-needed-fixed/p1
In any case, I am wondering now if when a hose is screwed into the city port & under pressure, that this may temporarily seal the leak around the loosened threaded collar around the check valve. However when the water pressure is coming from the pump side of the city water check valve and there is not any opposing pressure from the other side, then it leaks. So, while the connection is still loose on the inside, it only leaks when water pressure is coming from the inside, and not the outside (or perhaps when a hose is also fitted into the outside socket). Just a theory, but also an observation.
If you pull the toilet, this is what you will see. There is a seal provided. It should be soft & pliable. You will notice that nucamp has sealed the floor pan pretty well, but I suppose it is possible that it could leak....the red thing is a stool cork that I had to prevent “sewer gases” from leaking...
