we own a 2020 320s boondock edge. so my plan before we head out is to cool down the fridge on shore power the day before, put some ice in to keep it cool. my question is simply, since my truck does not charge my tab battery while we drive, do i leave my battery disconnect off while driving? since my solar is charging the battery with the disconnect off:)
2018- 400- Colorado V6-Marin MT bikes
0 ·
On your questions:
Your truck should be charging the trailer battery. The charge line should be pin 4(?) on you trucks 7way plug. Have dealer check it.
Your trailer has electric brakes. The power comes through the 7way plug from the controller under the dash. If you have none of this your dealer would have never let you leave the lot. Or should not have.
Odessa, Fl.
Of course a breakaway is a rare event--even though it is a full-on emergency-- and you can avoid the problem by always making sure you have the hitch securely locked to the ball and the ball securely affixed to the tow vehicle.
All Chevy Colorado 2015 and newer versions are factory wired for a 7-Pin trailer connector.
If you have a factory installed 7-pin or correctly installed aftermarket 7-pin the Colorado will provide voltage to the trailer batter (assuming the truck fuse is not blown)
Adventures: 58 Nights: 405 Towing Miles 50,180
Here's the last response from NuCamp:
"Yes the emergency brakes are electric and they are powered by your battery. However, the emergency brakes are hardwired directly to the battery so the battery disconnect switch does not affect the function of the emergency brakes."
But as GatorEgg mentioned, leave the camper in battery disconnect mode, hitch it up, don't connect the 7way plug to your vehicle, pull the emergency pin, the put it in drive and see if the camper brakes are on. Repeat with battery disconnect off. Then you'll know for sure for your year and model, and start driving with the battery on.
pardon my ignorance as i try to make the correct decisions and learn to protect my investment. thankyou.
I think we can agree that even with a two hour walk through you simply can't cover it all. On top of that we all use our trailers in a different manner, my example being I can't imagine not having a propane powered fridge and others who never use it on propane. Others who boondock nearly exclusively to those who never boondock. Huge differences in how the trailer gets used which may lead to very different answers to the same question.
You can turn the refrigerator off while towing if you want to (assuming the refrigerator has been pre-cooled, as you have described.) Avoid opening the refrigerator door to maintain the cold temperature as much as possible. Just remember to turn the refrigerator back on when you reach your destination, or when you stop for an extended period (e.g., if you stop to eat, or to rest for an extended period.) HOWEVER, during those stop/rest periods, you should use the propane setting to cool the refrigerator. If you use your battery only, the refrigerator will discharge it quickly.
Some feel it is OK to drive with the propane on (to maintain the refrigerator temperature), but I do not. It is an ongoing debate. If you search for it on this forum (or Google it), you will find discussions about the pros and cons of using propane to keep your refrigerator cold while towing. It is pretty much a personal preference.
Greg & Marlene (Tucson, AZ)
As an aside, you might check out the search feature in the upper right hand of your screen. Type in a key word or 2/3. The search will usually brong up several to many threads on your desired topics, where you can read at your leisure and until you are up to your eyeballs in that specific topic.
Tow with the battery switch on ALWAYS! Enjoy the journey. -Denise
