Safe Adhesive Removal From Window ?
The dealer put an inventory sticker on the side window when I had the 400 in for warranty work. Any approved, safe means to remove the residual adhesive from the acrylic window?
Goo Gone
Finger nail remover should work - use a micro - fiber towel and rub only very lightly
TV:2019 Nissan Frontier PRO-4X With an Old Man Emu liftTrailer: 2019 T@B 320 Boondock with a Lock&Roll Coupler & Jack-e-upCustom fabricated metal bottom claddingCalifornia, USA0 -
Are those tried and true methods, manufacturers recommended method?0
If Cherokee means fingernail POLISH remover DONT!! That is acetone and inimical to acrylic. Test Goo Gone on an unobtrusive part of a window. Clean the Goo Gone residual with dish soap and water. Then use Novus plastic polish to clean the windows.
https://www.novuspolish.com.
3 -
Aren’t the TaB windows polycarbonate, instead of Acrylic? If so, polycarbonate is a lot tougher to scratch or shatter...
TNOutback said:Are those tried and true methods, manufacturers recommended method?
I've used acetone (finger nail polish remover)to remove various sticker residue on plastic trim before with good results. However, I haven't used it on a T@B window and given it's possible ill effect on polycarbonate, my recommendation is in error, Sorry for the inconvenience.
all I know is that you don't use windex on them...plexus is the only thing I was recommended to use..I'd call the factory...Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada0 -
Yes, knew about Windex, thanks for the tip about plexus.
1. Find a hospital nurse.
2. Have them appropriate a bottle or vial of V. Mueller Whisk adhesive remover.
3. Use a soft towel to remove adhesive.
This stuff is worth it’s weight in gold. Removes any adhesive from any surface without damage.
Huntington LI0 -
I always try WD40 first. It works most of the time.
- Hash T@B Fun
The safest adhesive remover for plastic or any surface is vm&p Naphtha, Can be had from any paint store or Home Depot. Do not use nail polish remover on plastic.
Every house hold should have naphtha on hand, it's great for glue, markers, wax, etc.2018 T@B 400+++2016 Chevy Colorado, 3.6 V6
Hamburg, NY0 -
Also, naphtha works great to remove butyl tape and Dicor lap sealant, for those who want to re-seal their campers
Hamburg, NY1 -
Here is what I got back from Creed at NuCamp:
I don't have a specific recommendation. But you could google search the best method for removing adhesives from Acrylic. Here is a website that I found through my search - it sounds like baby oil and vinegar are some examples.
https://www.hunker.com/13419628/how-to-remove-adhesive-from-acrylic
I emailed Plastoform (the acrylic window manufacturer for our T@B windows) about what to use to remove the adhesive. They asked me to send them a picture of the adhesive, which I did. Their instruction was to use Isopropanol (common household rubbing alcohol) and a soft cloth to remove the adhesive.
They also provided a “safety sheet” that contained the following regarding cleaning of the windows:CLEANINGNever use abrasive and corrosive substances or solvents on windows, such as turpentine, spirit, dishwasher detergents, as they will damage acrylic and/or print. We recommend cleaning with generous amount of water or mild cleaner intended for use on acrylic. Every cleaning with dry cloth can damage the acrylic and leave scratches; always use moist sponge or moist soft cloth. Never clean windows with high pressure washer. Also carwash can damage windows and cause scratches or other damages.Acrylic material can get scratched very easily, please consider above instructions for cleaning, so that you will not cause scratches or other damages while cleaning.1 -
I used Goo Gone and a microfiber towel, put a dab on the corner of the towel; I put the wet corner of the Goo Gone on the adhesive for a few seconds and then lightly rubbed and it came right off.
2020 400 BDL aka "Boonie"
Concord, NC0 -
Well, the rubbing alcohol, along with a cut-up old T-shirt, did the trick. @Dutch061 , per the manufacturer’s instructions, any kind of solvent should not be used. I have and use Goo Gone on other things, but I didn’t want to risk messing up the window.
On another note, I asked Plastoform about those weird icon stickers, and what they actually mean, and I was surprised at the answer: you are not to have the shade closed in direct sunlight! They said it can deform and permanently damage the acrylic window due to the heat buildup between the shade and the window. That’s when I want the shade!1 -
@TNOutback, as a follow-up to your comments about the meaning of the window sticker, and just to add a bit more info on it, see the October 2019 by @jimcenname on the below discussion thread:
https://tab-rv.vanillacommunity.com/discussion/comment/128642#Comment_128642
Greg & Marlene (Tucson, AZ)0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
