Does anyone have suggestions for getting hot water to work in the outside shower of our 2019 400? We have adjusted everything we can think of (thanks for several threads on the forum) but still taking cold showers. Water temp is 133 degrees and works well inside the trailer at all locations. Thanks.
2019 T@B 400BD, 2019 Ford Ranger2008 Jeep Liberty, Southern CA desert
0 ·
You may have a defective shower mixing valve or ?
I am not familiar with those connections on the 400 (presumably, they are the same as on the 320 S), but in the photo you provided above, I do not see a water line going from the "hot" (i.e., red) pex line. I am curious, because I only see two white water lines, and both are connected to cold (i.e., "blue") pex lines; one is connected to the water pump, but I can't tell where the other one goes. [I could be wrong, but I am assuming that the white water line with the blue stripe on the left side of the photo leads to the fresh water holding tank?]
Greg & Marlene (Tucson, AZ)
https://tab-rv.vanillacommunity.com/discussion/3167/outside-shower-is-disappointing-looking-for-potential-mod-ideas
This is the outside shower I have on my 2019 320 S Boondock Lite. It is also available in black:
https://www.amazon.com/Fontanna-97022-Compact-Exterior-Shower/dp/B019F81FQ0/ref=sr_1_4?crid=2QR7FKUW4N05W&dchild=1&keywords=fontana+rv+outdoor+shower&qid=1593294771&sprefix=fontana+rv+s%2Caps%2C213&sr=8-4
If there is a separate mixing valve for the shower, and if it is not part of the shower head itself as mentioned in the above discussion thread (which, I don't see how it could be), my guess is that it is contained within one of these parts of the shower. Regardless, it does not appear that there is anything capable of being adjusted:
https://www.amazon.com/Fontana-97020-080-DB-Replacement-Straight-Nipple/dp/B015Q89WA4/ref=pd_vtp_263_1/131-5522919-2037216?_encoding=UTF8&pd_rd_i=B015Q89WA4&pd_rd_r=a9fb70fa-8c85-4f46-bb99-241d000e51d9&pd_rd_w=IbfCW&pd_rd_wg=42znl&pf_rd_p=59828acf-6bde-4d94-96a5-3e2b4a0e0bc6&pf_rd_r=DJRC84KKGAF6THVAKS5G&psc=1&refRID=DJRC84KKGAF6THVAKS5G
OR
https://www.amazon.com/ITC-97022008-Exterior-Shower-Repair/dp/B007HRVOHW/ref=pd_bxgy_img_2/131-5522919-2037216?_encoding=UTF8&pd_rd_i=B007HRVOHW&pd_rd_r=6f66d9a8-e691-4af2-ae5f-b6f3ae961174&pd_rd_w=D1wWx&pd_rd_wg=bXhr9&pf_rd_p=ce6c479b-ef53-49a6-845b-bbbf35c28dd3&pf_rd_r=S3X6VR3P2ZKKK73ETKD0&psc=1&refRID=S3X6VR3P2ZKKK73ETKD0
