TV smaller sized spare tow or no
2020 T@B 320 Boondock
Factory Victron Solar, Norcold 3 way Fridge
Clueless about everything electronic
2020 Subaru Ascent
Bainbridge Island, Wa
Good question @Kr@cken. Not a rookie question. A question I have not seen until now. Anybody?
This is graduate level stuff.
Towed by 2014 Touareg TDi1 -
@Kr@cken, I do not have any experience with a situation like that, but I found the below information posted online by an RV owner. I am only providing it to you for consideration, but it makes sense and I personally agree with it.
Your best bet would be to consider subscribing to a tow service that includes towing coverage for your T@B (e.g., AAA, Good Sam, your auto insurance provider, etc.) If you search this forum, there have been discussions in the past about available options, but you will want to confirm that it covers both your tow vehicle and trailer. Otherwise, you will need to leave the trailer on the side of the highway while you are getting your tow vehicle flat repaired/replaced. The only exception in my mind is that you might be able to get away with it if you only have to travel a very short distance (e.g., to get the trailer off the highway and to a safer location, or if a tire shop is close by.) BUT, if you choose to do that, you will need to drive at a low speed (25-30 mph?), which you are supposed to do on an emergency spare anyway.
Here's the post (from an RV forum):“If you do not have a full size spare and instead a “donut” emergency spare (smaller), then you should not be towing any trailer. This emergency spare can not handle the additional stress of towing. So, you would have to leave your trailer on the roadside if you did get a flat on your tow vehicle and have to use the donut spare.”
Thank you for your prompt reply. I do have AAA with the RV package so I will check with them to see how this would be managed. With AWD I wasn’t sure if the remaining 3 wheels would be sufficient to manage the offset distribution. I will be low and slow in the right hand lane.Kr@cken
2020 Subaru Ascent
Bainbridge Island, Wa0 -
An older entry from a Subaru dealer website (https://www.stanleysubaru.com/blog/2012/october/18/how-do-i-change-a-flat-tire-in-my-subaru.htm):
Never tow a trailer when the temporary spare tire is used. The temporary spare tire is not designed to sustain the towing load. Use of the temporary spare tire when towing can result in failure of the spare tire and/or less stability of the vehicle and may lead to an accident.
Pacific NW1 -
Thank you. I called Subaru earlier today and they didn’t seem to think it was an issue. Glad I came back to the experts.Kr@cken
2020 Subaru Ascent
@Kr@cken, I opted not to include it in my earlier response, but since you brought up AWD, I also saw this comment, which was from another RV'er:
“Also, be careful if you have all-wheel-drive . . . . in some cases, it could cause extensive damage if you use a tire that is a different diameter than the others. Make sure your spare matches, whether it is a "donut" or full-size.”
I didn't include it primarily because a "donut" spare is smaller (at least that has always been my experience), despite it being sized to work with the particular vehicle. If a vehicle includes a "tow package," then it should include a full-size spare (although it may be the stock spare, as opposed to an upgraded tire and/or wheel size, which is common with newly-purchased vehicles.)
Whatever any RV owner on this forum does, always err on the safe side. If it isn't a hazard to other drivers, and you don't have a tow service, it's best to just leave the trailer alongside the highway. Hopefully, you won't be away from it for long and you can secure it with a locking device to deter theft.
I was thinking I would stay with the camper until they bring my TV back
Kr@cken
2020 Subaru Ascent
Bainbridge Island, Wa1 -
Couple of years ago, I was at on the North Rim of the Grand Canyon off a 7 mile Forest Service road.....with a rear tire practically flat from a large chunk of metal. Luckily, the tire held air from the compressor long enough to maneuver, and things worked out.If this had been an actual emergency......I'd use one of the small tires on the front wheels and drive ever so slowly and carefully to where I would find help.
Towed by 2014 Touareg TDi2 -
I bought a compressor and a tire plug system so hopefully I can get my full size tire home. I miss my old Toyota Venza that had had a full spare tire,Kr@cken
2020 Subaru Ascent
Tire plugs were used at the North Rim Country Store near the Demotte Campground to fix my tire. The guy who did it (Tom) had a crowd around him as he worked his magic on the tire, since this method of tire fixing seems to be a bit rare. Held together just fine. I carry a plug kit now, too!
@Kr@cken I agree that trying to tow with the temp is not a good idea. I also have an Ascent and just to keep things complicated, the Subaru manual says the temp spare should not be used on the front axle because of the difference in tire geometry mentioned by @Bayliss above and the AWD system. So if you have a front flat you need to remove the rear tire, put the spare on the rear and then put the good tire on the front. Plus, if you camp anything like me, the back of your Ascent is probably filled to the roof with gear so good luck deploying that spare! A plug kit and compressor might suffice to get you going, but a good roadside assistance plan is good insurance.Richie, Mickie and Satchmo
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium0 -
For all the trouble a flat tire would cause while towing, I'd be inclined to just buy a cheap Subaru rim and mount a full-sized tire to bring along when I am camping. Some flats can't be plugged or even professionally repaired--even with roadside RV assistance insurance, you might find yourself waiting a loooong time for tow trucks and tire replacements when just having the right thing on hand would have gotten you back rolling in fifteen minutes. Just my $0.02...2015 T@B Max S (320)
2015 Nissan Frontier SV V6 4x40
