We are camping near Sugarcreek and had the factory solar system installed in our 2019 T@B 400. I paired my phone with it yesterday and was able to read the amount of amps the solar panel was generating and all the other information that the program provides on the APP. This morning I could not get the program to show me any info... I told the iPhone to “forget this device” and tried to re-pair it.. Now my phone will not show the Victron on my list of devices... I have turned the phone off and on several times and it will not show the Victron of my list of discoverable devices.. Can any one help with this? Thanks...
0 ·
But most devices from the last few years use a Smart Bluetooth low energy protocol that needs location data to help bind. Once bound, you can turn those services back off. Oh, and turn off any VPN on your device for that initial pairing.
May not be it, but something to try if you've already turned your phone's BT off and on, removed existing pairings, and all the other normal fixes.
The Apple developer's guide suggests for pairing with BLE devices an app should check the Location Services / System Services status and prompt the app user to turn those on if disabled. But not many developers remember to do that both in the iOS and Android world.
deleted the app
turned off the phone
Turned phone on
reloaded the app
(several times)
I even disconnected the controller on hopes that it would reset.
Once I got a message that it was “already connected to another device”.
Or, should I be getting another code via the Bluetooth connection? Which, sometimes connects and other times it doesn’t.
Here is my new battery setup ... hope it is correct!
I am waiting to reset the controller (once I figure it out). I did install a new converter (Progressive PD4100) and an onboard Progressive EMS. I am also installing a NOCO onboard Gen5x2 for charging and maintenance as needed.
