I have a 2021 Tab 320s
The hot water tank is filling up and then gushes out of the overflow valve and onto the ground. Nothing in the cabin. When I turn off the water source and the Aldi system, it stops. It happens on both city water and dry camp modes when I turn the pump on. Any ideas about what is causing this? Thanks
Adventures: 57 Nights: 399 Towing Miles 49,190
Is it possible the hot water drain is open? Since the HW drain is after the Alde, this would seem consistent with the symptoms as described.
Leadville Colorado
see this thread: https://tab-rv.vanillacommunity.com/discussion/15014/on-the-road-hot-water-spewing-out-the-bottom-of-t-b400-now-no-hot-water
