Positioning a disconnected camper in soft soil or sand
TerryV6
TerryV6 Member Posts: 1,101
We were at a campsite this weekend.  It had a soft dirt base .  I backed in, put a board under the wheel and by using 3 boards total and moving them as a running bridge, we’re able to swing the camper 90 degrees to face out.  The first time we’d been there, the wheel sank into the dirt.  Thus I knew how to solve this.  I’m wondering if there is a more elegant method someone has come up with for this problem.
2016 NuCamp 320 T@B Max S
T@bbey  Road
Appleton,  WI
  • AnOldUR
    AnOldUR Member Posts: 1,761
    Might not be elegant, but search for 747 mod …
  • SLJ
    SLJ Member Posts: 666
    edited July 2022
    I use boards all the time. Usually carry three 2x8x16 for leveling and to keep above soft ground. Later this week I'll I'll probably take a couple extra also as it raining cats and dogs there today and the field may be pretty soft still so I may need them under both sides and the jack.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • TerryV6
    Thanks everyone for the response.  I used to be here a lot, but have been "distracted" a bit for a while.  I've done a lot of mods from here, especially many of Dale's...  I looked up the discussions and saw all the different ways to do this, especially Dale's ...  Some people had trouble with tire pressure or other problems with pneumatic tire.  I might be wrong, but it looks like he reverted to some large orange plastic mats to use..  decisions to be made....
    T@bbey  Road
    Appleton,  WI
  • dsfdogs
    dsfdogs Member Posts: 641
    @TerryV6 I've missed seeing your posts! I hope all is well - happy camping!
    Debbie in Oregon
    Sold 2023 Tab 400
    Sold 2018 T@B 320S
    We carry large plastic pads for this purpose.  Used to carry cuts of plywood.  We have never needed them - knock wood.
  • TerryV6
    This just shows I’m  getting older.  There was a discussion on this a few years ago and I even contributed.  I didn’t see the plastic pad idea though.  I’ll have to look for some larger ones…
    T@bbey  Road
    Appleton,  WI
    @TerryV6 - Camco Large RV stabilizer pads via Amazon
  • Marceline
    Marceline Member Posts: 1,779
    What about some traction mats?
    Denny16 Member Posts: 5,430
    edited July 2022
    That is a good idea Marceline, traction mats would be a very good solution.  The thicker off road recovery boards cloud also be used to help level on soft ground areas.
  • TerryV6
    thanks all for the suggestions.  We went with camco pads.  We won’t use them often $17 was okay for me.  We will see if they crack when moving the jockey wheel over them. They are 14x12, so perhaps two more if I need to traverse the camper to a new position.
    T@bbey  Road
    Appleton,  WI
