PXLated said:RZRBUG - Before I did anything - I found it easily swivels to up or down. All mine had in it was some small plastic shaving, not many though.
Right, and once or twice should permanently take care of those. I also took off the filter/fitting at the end of the faucet to see if any had made it to that point and did not find any.ChanW said:
And RZR, it's funny cuz all I found in mine was PVC filings... B-)
I've occasionally had the same experience with backup when filling. However, it usually burps itself out with a few seconds rest.PXLated said:Thanks Chan - Filter was clean - Turned out fresh water tank was pretty much empty. I had tried to fill it at the last dump/fresh water station and it only took a couple gallons so thought was full as it was backing up. Only thing I can think of is maybe the vent tube wasn't allowing air to escape so there was a big bubble keeping fresh from going in. The first gallon or two this morning I had to pour in real slowly then it seemed back to normal.
