Greg & Marlene (Tucson, AZ)
Yep. When I removed my television I found that a mounting screw had been run through one of the power leads (note the nick in the black wire at the bottom). Unfortunately such goofs can and do happen and may cause developing and intermittent problems over time. Even if all the wiring is intact, sketchy connections within components can cause the same symptoms.N7SHG_Ham said:...Basically a though job will be looking at every inch of wiring on that 10a fuse circuit....
