Wanted: Ideas and thoughts on moving the spare tire to the trailer tongue!
2»
  • Ratkity
    Ratkity Member Posts: 3,770
    PXLated said:
    Verna - They're so easily set up :-)
    I smelled a PXL set-up from a mile away - good thing I read it before coffee! My mental image couldn't be conjured up and my little bit of sanity remains intact (for now). He might try it again in the future (*pffft "might" he WILL).
    OP - use the BLUE loctite. The red one is permanent. Make sure you have a good lug wrench you can get the lugs off - V, I and others have a versatile lug wrench set that has two sockets (17 mm and 13/16) - https://www.amazon.com/gp/product/B004SEXO3E/ref=oh_aui_detailpage_o06_s01?ie=UTF8&psc=1
    I also carry a crossbar lug wrench, but the jack would get in the way. My solution was to put the spare on a Yakima rack like the Outback has. Pricey, but for piece of mind.
  • leenscottfl
    leenscottfl Member Posts: 254
    This is how I placed my spare. Left a perfect place for my 12 gallon Smart Tote dump tank.
  • Lil_Lucy
    Lil_Lucy Member Posts: 82
    ericnliz said:
    Thanks Mike. I just have concerns about the integrity of the crank structure mounting the tire in such a manner. I go boondocking quite a bit, and the bouncing/jarring effect would be a concern to me. The reason I started this thread was to get some real-life feed back from those who have done this mod and the pluses and minuses of the mods themselves. As always I appreciate your comments and concerns about the weight factor and re-sale issues. The weight factor of the tire/wheel assembly is not really an issue for me as much as the original location of the assembly. I am looking for something that can in fact be easily removed for re-sale, and still stable enough to not have to cause concern.
    ericnliz:
    Here are some pictures of my spare mounted to the jack crank. I just used a standard frame mounted carrier and used muffler clamp bolts to bolt it on. (You may have to drill a new hole or two in the bracket). This configuration has stayed on and in place for two trips from Michigan to Oregon and back without any problems.
    P.S.
    You will notice it also makes a handy place to hang your hitch chains when not towing.
    As for the spare tire bracket underneath the T@b. I left that there and utilized it to mount a sewer hose carrier. I just built a bracket that attaches right to it. All these modifications can be taken off and everything will be right back to original.
    2016 T@b 320 Max-S (Silver/Red Trim) / TV: 2019 Ford Flex
    "Growing old is mandatory. Growing up is optional."
  • Nomad
    Nomad Member Posts: 7,209
    The crosswise tire looks to me like it would always be in the way when accessing the tub/battery/propane. Maybe it's because I'm short with matching arms and have to get in close.
  • ChanW
    ChanW Member Posts: 3,165
    Yeah but..., I don't know if I've ever accessed the tub/battery/propane from the front. I usually deal with it from one side or the other...
    Your tire would definitely be in the way (for me) of getting at the propane, especially if it was the middle of the night, what was it, in pink skivvies?
  • Nomad
    Oh no, you joining the thugs picking on me?
    I'll get even :-)
  • Ratkity
    @Lil_Lucy I see the radiator clamps on the sewer hose holder underneath. I have 2 bolts that hang down that held the spare underneath. How'd you modify those to the clamps? I really love your mod!!!
    Lil_Lucy
    How difficult is it to access the sewer hose, and have you bottomed out with it in that position?
    ScottG Administrator Posts: 5,674
    Sorry, PXL. I'm also, um, compactly constructed, and I agree with Chan. You need to relocate your spare ASAP!  :-)
    I'll get even :-)
  • Lil_Lucy
    Ratkity:
    Attached are close up pictures of the bracket I had made that bolts right to the spare tire bracket and the 46" hose carrier. The hanger straps you see on the ends were just added as a back-up measure should the bolts come loose or break. After two trips from Michigan to Oregon everything is still tight and holding well.
    P.S.
    I used a 46" hose carrier because it fits perfectly between the stabilizer cranks.
  • Lil_Lucy
    SAM said:
    Lil_Lucy
    Sam:
    There is no problem accessing the sewer hose. I just bend down on one knee and twist the cap off. The hose carrier is actually nestled up higher than the spare tire bracket itself, so I have never bottomed out (yet!!!). All this keeps the spare tire bracket original in case some would ever want to put their spare there.
  • Ratkity
    Thank you for the picts, @Lil_Lucy! They explain so much.
  • ericnliz
    ericnliz Member Posts: 4,437
    Lil_Lucy, Wow, thanks for the photos and description. Looks like a great solution to the problem.
    PXL, Thugs? Really?  =)
    ChanW, Atta boy! ;)
    2016 T@B MAX S-aka: WolfT@B
    Eric aka: Lone Wolf
    Where's PXL today?
    Is he hiding from the thugs?
    Did he fall into a dead zone again?
    Did he ever really exist?
  • Verna
    Verna Member Posts: 6,876
    You guys picked on him too much!
  • ericnliz
    Verna, Never enough! Besides, he does get even.
    ScottG, good one!
    Or..... maybe he got zapped with Verna's magic wand! =)
    Pxl, If we didn't like 'ya we wouldn't pick on "ya! ;)
    Eric aka: Lone Wolf
  • Nomad
    No cell coverage until this evening - So many thread updates I'll never see who I need to get even with - But I can probably guess:-)
  • ChanW
    Uh-oh, watch out Ratkity
  • Ratkity
    Bahahahahah Chan! Except I'm a wee more accurate! :wink:
  • Nomad
    But it's not your accuracy that will count but mine - off to go mole hunting :-)
  • ericnliz
    Good one PXL!
    Verna, I told you he gets even!
    Eric aka: Lone Wolf
