My neighbor and I had a heck of a time pushing my t@b into his yard (the alleyway is pretty narrow and I wasn't able to back it in while hitched - will try again next time). First issue is that it's gravel, although it's semi hard-packed so not TOO bad. The biggest issue is getting it over his gate threshold. We tried pieces of wood but they moved around too much. So without spending a bunch of money, can anyone think of something to put over this lip (see pic)? Was thinking a piece of rubber t-threshold but whatever we use has to fit over the metal - that t-threshold stuff is supposed to fit inside a track. Anyway, suggestions appreciated - I'll be taking the trailer in/out of his yard so need to come up with something.
0 ·
When moving my Harley, I tried a piece of half inch plywood (cut at an angle at each end), and then had a 6' x 40" wide piece of "non-skid" rubber made for a truck bed. The no skid mat, skidded and I heard the plywood crack. Keep in mind I had 750# of bike on 2 fairly narrow tires and not dispersed over a wide axle. I was thinking about thick (but not too thick) diamond plate next instead of plywood.
The running start didn't help - we tried that a few times! Luckily his contractor drove up as we were trying (plus a neighbor) so we finally got it in. If that dang lip/metal wasn't sticking up, I'm pretty sure just he and I could do it.
Alan & Patty
Southern Az
Eric aka: Lone Wolf
Living in our Airstream, traveling in our 2017 T@B Basic S
Married to Dave-aka, ds@work
Model PC-2 Power Caster $1,275.00
Designed for medium travel trailers
- 800 lb. tongue capacity
- 6,500 lb. laden weight capacity
- 1/2 horsepower electric motor
800 in.-lbs of torque @ 30 RPM(120 volts, 8.3 amps)
- Weight 77 lbs. (boxed shipping
http://powercaster.com/Products.htmlweight approx. 97 lbs.)
3/4" clearance between roof eves and top of Tab.
That is slick... and no permanent installation on the T@b.
This picture is a little deceiving because the first time I used it, I had a ball hitch adapter that the original owner had put together. But that isn't the way it works. The tongue jack slides in where you see the ball hitch so that it is a solid connection. Otherwise it will want to fall over and you constantly have to fight to keep it upright. I did purchase their 2" adapter and bolted it to the frame, because it's just easier to use that way. You jack it up with the tongue jack then slide the dolly on to the adapter then pull the jack up and remove the wheel. Otherwise you would have to set it on jacks and remove the wheel then move it on the dolly. As far as I was concerned it was well worth the expense. I can do it all completely by myself. Even if my back goes out like the last time I was putting the trailer away I thought is would be a good idea to lift up the tongue and put it into one of those yellow jack wheel stops. Which turned out to not be a good idea.
@Sandiegogal, It's ok, Liz doesn't watch either when it goes in. I know this because I've asked her how much room I have & she says..."I don't know, I can't watch". Oh, boy, should have just asked the neighbor's dog, at least he'd bark when I got close to the fence!
Eric aka: Lone Wolf
https://www.youtube.com/watch?v=JvyU6KwptAA
https://www.youtube.com/watch?v=V3AM88sfDuc
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
What 30 amp plug?
Oh I think I understand....we don't have the AC, so I just use an adapter and plug into a 110 20 amp plug...my leaf is plugged into the 30 amp dryer plug.
I'm with her....eeeekkkkk!!
That was just a bit of playful sarcasm, noting the clearance of the trailer sidewall to your home and wondering how you were able to plug in the trailer via the 30A power cord when distance was minimal and things were so tight. It definitely looks challenging, but your tow dolly obviously performs well and your neighbors no doubt are impressed too. Well done!
@Sandiegogal finally explained it to me. You would think I would have caught on a little quicker because I'm the one that had to lay down on the ground and plug it in from underneath
Hmmm...this sounds like an inexpensive solution - I'll check out where to get one.
rfuss928 - I hadn't thought of driving nails into the wood - that might also work.
JkJenn - those are also a thought...
The dolly is out of my budget - I like it, but will try some of the other ideas.
Thanks everyone!
I'm in my neighbor's yard so cannot do anything about the "track" where the gate comes across. And it's in an alleyway which is fairly narrow so I wasn't able to stay hitched and back it that far (someone with more experience may be able to) --- I'll try again next time I take it out). But for now I like the rubber mat idea.
