Outback Stabilizers
Seaduster
Seaduster Member Posts: 147
Those of you with the Outback model... how many stabilizer leveling blocks are you typically using.  They gave me 10 blocks with the trailer, but I'm using 8 of those under the two backend stabilizers when parked at my off-site storage facility.  Will I need additional blocks?
2017 white/black trim T@B Outback; 2017 white Subaru Outback; Seattle
  • jkjenn
    jkjenn Member Posts: 6,425
    Holy cow! I have never needed to use that many, even when in a crazy camping spot. I don't own enough to go that high. At one site, I used some flat rocks to help out.
  • Seaduster
    My T@B's storage spot is on a bit of a slope.   Just wondering how many are necessary in a regular campsite.
  • Ratkity
    Ratkity Member Posts: 3,770
    My sister's Outback typically took 4 blocks per rear stabilizer. Sometimes she needed to borrow blocks from me if it was a sloped site with no other options to move the trailer into a more optimal position.
  • ColoradoJon
    ColoradoJon Member Posts: 415
    I normally use 2 or 3 for the rear stabilizers if the ground is relatively level.  If the ground slopes down at the back then yeah, bring extra!
  • Rolltide82
    Rolltide82 Member Posts: 89
    2 for rear on mine 1 for the fronts
  • db_cooper
    db_cooper Member Posts: 749
    edited April 2017
    On level ground (i.e. my gravel pad at home),  I need two blocks in the back, and I use one in the front.  We've camped in a few crazy spots,  but usually if one side needs a bunch, the other sides don't.  Instead of carrying more blocks for the off chance,  I'd either improvise or just not worry about it.  If you get 3 legs down, it's pretty stable I think.  Come to think of it, I carry a collapsible stool from Walmart that would make a nice tall block in a pinch.
  • Estancio
    Estancio Member Posts: 243
    Never use blocks to level the camper. Have always been able to manage just fine utilizing -- which camping spot, which way we park, and which direction we sleep.
    Stancil Campbell
    2011 T@B
    Rockingham, NC
  • PNWtabber
    PNWtabber Member Posts: 492
    When I bought my T@B from the original owner, they included a set of "Lego" blocks (qty 10) and Andersen Tuff Pads (qty 3).  I often find I use every one of them.  I'm looking at some different options; e.g., Ox Blox or something similar.  I find it is often a stretch to get those rear stabilizers supported.
    MuttonChops Member Posts: 2,088
    @Seaduster ;  I use wood blocks in addition to the Lego Levers.
    On Each Leveler 'Foot' I've mounted a cut-down 2x8 board, screwed to the foot and painted black.  I also have four 2x8x8 Red painted blocks.
    Even on a level paved surface I use the Black & Red combination as it reduces the angle of the stabilizer arm.   From time to time while camping another Lego Lever is added to the stack as needed . . . 85% of the time Legos are only used under one tire for driver-passenger leveling.
    Reference:
  • PNWtabber
    @MuttonChops I like your system.  For myself, I live and camp in a very wet environment (Western Washington).  Not sure wood is the best material for me.  :s
    Denny16 Member Posts: 5,430
    You can get a piece of 2x6 non wood decking board made from recycled plastic bottles and wood bits.  These deck boards are basically water proof/restart and will not rot due to moisture.  Nice idea, BTW, MuttonChops.
  • PNWtabber
    I've considered that.  I've used Trex for other projects before, but it seems potentially slippery when wet.  Will check into it again.
    You can rough up the surface of a Trex board to give it more grip, or glue some 40-60 girt wet and dry sandpaper to it, which will not slip…
