No 12v
Night one of trip....no 12v. It worked when I tested it 2 days ago.
- Trailer running lights, brakes, and turn signals all work OK.
- Battery is reading fully charged with the multimeter and the Victron.
- 12v fuse looks good
- Nothing has power inside.
I am going to start by moving the house negative from the bus bar, tomorrow. Tge tray cable from the shunt load side to the bus bar has a fair amount of corrosion. If that solves it, it's easy enough to buy a new tray cable, especially since I am overnighting at Walmart.
I can try shore power, tomorrow, by plugging the 30 amp into the GZ Yeti 1000.
Open to other suggestions. It would be a bad time for the converter to go bad. Ut has been bad luck for this summer with power related things!
