Replace gravity fresh water fill?
lkc001
Member Posts: 877
Anyone replaced your fresh water fill? I thought I read somewhere someone had done this & it is easier to fill the water tank?
2018 Tab 400
Towed by 2014 Touareg TDi -
I guess it depends what you mean by easier. It's still a gravity feed so a different filler won't necessarily resolve the "burping" issue raised in another recent discussion.I find that I'm often filling my tank from a jug with a pour spout, so the original little flapper door thingy--despite being a bit leaky--works pretty well for that purpose without requiring additional hoses or connectors.2015 T@B Max S (320)
After a year, we managed to crack the original cap for the Fresh Water Fill. We replaced it (per nuCamp) with the threaded JR products polarwhite version purchased via Amazon. We still use a silicone adapter spout that screws onto the end of a hose.
yes, that little flapper door gets in the way. . . I'll check out the other thread mentioned here--Thanks!2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab -
FWIW, I do fully expect to break that little flapper door at some point, and am surprised it hasn't happened yet. Maybe the first mod this season will be a new fill port and siphon for my jug!
Thanks everyone for all the info!2018 Tab 400
The little flapper does not usually break. It can snap out of place. With a little work it can be snapped back into place. I’ve done this 2or 3 times.
- Hash T@B Fun
Yes, we snapped it in and out of place, then cracked it. I think it happened when we were filling using a heavy water jug. Anyway, the siphon solves that heavy lifting task.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Mine broke off (plastic broke.)Dalehelman said:The little flapper does not usually break. It can snap out of place. With a little work it can be snapped back into place. I’ve done this 2or 3 times.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
@jkjenn you just don’t know you own strength.
- Hash T@B Fun
Lol....heavy 5 gallon water container slipped.Dalehelman said:@jkjenn you just don’t know you own strength.2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I bought this part but I couldn't figure out how to get the old one out without damaging the trailer wall. Any tips?Sharon_is_SAM said:After a year, we managed to crack the original cap for the Fresh Water Fill. We replaced it (per nuCamp) with the threaded JR products polarwhite version purchased via Amazon. We still use a silicone adapter spout that screws onto the end of a hose.
I had it done by nuCamp. Austin and Mark did it.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Marceline,
It's got a bead of caulk around it. I think i used an old credit type card to loosen it. Once you the the screws out, gentle pulling pressure will get it out.
Be prepared for it to take longer than you think. I couldn't connect the new one as the hose was too short. The old fitting has a longer collar. I bought a short hose and a hose clamp to finish the job. 15 minute job took 3 hours. 😁
2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620 -
Mine is a 2013, which is the first year that Pleasant Valley manufactured them (I think). The fill seems to be glued in with something much stronger than caulk - maybe even epoxy. I tried heat and couldn't get it to loosen at all.db_cooper said:Marceline,
Be prepared for it to take longer than you think. I couldn't connect the new one as the hose was too short. The old fitting has a longer collar. I bought a short hose and a hose clamp to finish the job. 15 minute job took 3 hours. 😁San Francisco Bay Area
Marcelina, did you try M.E.K. to break the bond? Also try DeBond a spray solvent that is used to break the bond of 3M 5200 an adhesive caulk used in the marine industry.‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI
- 920 Introductions
- 74 Teardrop Groups & Links
