The fan in my switch box near the floor (2019 320s) stays on when the Tab is connected to AC power. If the Alde is off I don't see anything that would be generating heat and need cooling. I want to have the shore power connected so I can leave a dehumidifier on. Why does this fan run?
Tab 320s Boondock
TV: Toyota 4Runner
0 ·
TV: Toyota 4Runner
It will also run if I'm putting a large draw on the 12v system, like with the 3-way fridge.
But it shuts off once the 12v is no longer being used.
The fan you hear is from the converter.
Alan & Patty
Southern Az
TV: Toyota 4Runner
I guess I'll have to unplug the tab and run an extention cord thru a window to power the dehumidifier. Or maybe could remove a fuse to turn off the fan?
Mike in GA
TV: Toyota 4Runner
If it is you have every possible DC load turned on or some type of a problem.
Yes - - disconnect battery, still running ?
No - - check battery, water level, state of charge.
Yes - - Remove DC fuses one by one. Does fan stop?
Yes - - That circuit has a current draw issue that is not blowing the fuse.
Also, check to see that the WFCO Fan vents are clear. Dog hair for example is a known issue for reducing/stopping the fan from cooling correctly.
Adventures: 51 Nights: 322 Towing Miles 41,200+
2. disconnect battery, still running ? >Yes
3. Remove DC fuses one by one. Does fan stop? >Yes, either of bottom 2 fuses kills it.
> That circuit has a current draw issue that is not blowing the fuse.<
This is basically a new 320s outback so no dog hair etc. Only been out a few nights. fridge off, Alde off, lights off during my testing.
hmmmmm
TV: Toyota 4Runner
From past experience I don't have much faith in the dealer to know anything about the Tabs they sell. But it's under warranty so maybe NuCamp can help me.
TV: Toyota 4Runner
Fuse 1. Fridge and fridge fan
Fuse 2. Radio and TV
Fuse 3. Interior lights, porch light and Alde
Fuse 4. 12-volt outlet and charging center
Fuse 5. Water pump, sea-level, LP detector, ceiling fan and AC fan
Fuse 6. Battery charger
Fuse 7. Reverse hook-up
For my 2019 320 S, I believe that mine was wired as follows. I can't be certain on the details because I have modified it since delivery. If anyone can confirm the fuse sizes I will update my notes.
Fuse 1. (?? A) Interior lights, porch light and Alde
Fuse 2. (?? A) Radio and TV
Fuse 3. (?? A) 12-volt outlet and charging center
Fuse 4. (20 A) Fridge (There is no fridge fan on 2019)
Fuse 6. (30 A) Battery charger
Fuse 7. (40 A) Reverse hook-up
TV: Toyota 4Runner
Daryl
Thnx Scott. I actually cycled the circuit breakers already, no change. What I'm seeing, is on shore power, without the 12V battery connected I've no interior lights. When I bought the trailer, brought it home and plugged it in, battery connected, the furnace fan ran continually, so I pull that fuse. I read thru the furnace portion of the instruction manual, discovered the furnace switched on at the thermostat. The converter distributes AC & DC power fine tho. I'll order a new one.
Daryl
Yesterday I ordered this converter for our 2004 T@B:
http://www.bestconverter.com/WFCO-8725P-Power-Center_p_50.html#.XH_0IlRKhdj
This is the converter recommended in Richard Lewis's great e-book
101 Questions About T@b, T@da and T@g Camping Trailers
Today I got a call from Richard at Best Converter - he recommended instead this Made In USA converter, which he said is much better quality. I said yes of course.http://www.bestconverter.com/4135_c_226.html
