we used our alde last fall then winterized for winter. Last week we dewinterized and everything is working but the alde. I am trying to troubleshoot but no avail and looking for support.
Fuse not blown, hooked up to 30amp shoreline power, only using electric (not combo electric/gas), power at receptacle, hose levers all in proper position according to manual. I am not sure how to check glycol but I did not drain that last year.
What should I check next?
0 ·
2022 Ford F350 Tremor | 2022 Cirrus 620
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Do you have the digital display? Is that working?
Did you check the 2 Alde fuses located under the plastic lid AND the 12 v fuse in the fuse box? Assuming you have a 320, if it is plugged in under the bench, try it on LPG.
See Chan's photo below!
@db_cooper you should probably edit your post so no one follows it by mistake!
The thermal fuse is here, in this photo.
Please check that referenced thread.
We may never know! 🙄
Voice of experience.....
