Wish us luck - fridge repair
Our T@B is going in to a local RV place that does Norcold repairs tomorrow. It works great on electric but not on propane. They started selling T@Bs last year and the tech we talked to was aware that he’d have to remove the fridge. Bless his heart. Hopefully he can fix it and it won’t cost us a small fortune.
Will post results.
    @Photomom, blessings, low cost and an efficient repair wishes go out to you!
  • ScottGScottG Administrator Posts: 5,644
    Okay... good luck!
    Anxious to hear how this turns out. I have a tense relationship with my fridge so I like to collect info and problems and solutions. I figure my day is coming.
    Best of the best!! :lucky:
    The day isn’t off to a great start.
    Well @Photomom, I don't know where you got that!
    It's sunny and warm here in Buffalo!  :D
    (kidding... it's time.)
    Initial diagnosis is the interrupter is bad, BUT the tech had to clean out a bunch of debris and rust out of the burner box. Any ideas how this could happen? My first thought is those two vents on the front might let in rain and dust.
    He ordered a part so I’ll update later this week. Thus far I am pleased with this dealership, will do a review later too.
    @Photomom what year and model do you have? I’m guessing early 2016 or older. Glad you’ve got a great service guy! That’s half the battle!
    The debris and soot is a normal thing. The advantage of the new fridge is that the burner box and chimney have access through the lower vent to clean. It is a significant disadvantage on the older fridge because you have to pull the whole thing out to clean it.
    Where would the rust come from?  I have a 2017 320S with the two round vents on the front of the trailer. . . . following. ..
    2018 Tab 400
    We tried the fridge on propane when we got the T@B to be sure it worked, and then for one weekend in late summer when we camped without hookups. The next time we tried was a couple years later when we were getting ready for a trip to the Adirondacks. I wonder if we should be making a point of firing it up on propane every month or so to dry it out.
    While I know nothing about gas/LP fridges and furnaces, I do know from watching the furnace repair guys at home who always had a shop vac to clean out around the burner because there was always debris there. And it was a well functioning furnace.
    Could it be that the dust, etc. is a normal byproduct of the actual combustion occurring?
    edited March 2019
    Except that we really hadn’t used it. Moisture is a byproduct of combustion, so that might have been the original cause of the rust. Wondering if we should put some kind of moisture absorber in that area between trips. Hope we get a chance to discuss with the tech when we pick the trailer up..
    Please post after the fix on what the tech says about the rust& debris— hope it is an inexpensive & simple fix for you
    2018 Tab 400
    My guess is the rust is post LPG use condensation as Photomom suggested.
