Hi everyone, I have a 2018 Tab 320S and can back it up without trouble, but need to get it into a tiny urban backyard via narrow driveway and gate then make 90degree turn to park it. No room for the tow vehicle, so looking at trailer dollies. Does anyone have any experience with either manual or motorized that work well for someone with some concerns about back strain?
thanks for your help!
northwestinatab
0 ·
Best thing I ever installed on my T@B
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
Woohoo!
Woohoo!
I consider it a necessity in my case, as I'm solo, disabled, and I will be parking in a spot tricky enough to drive a car headfirst into...let alone back a trailer in there. In my situation, it will pay for itself within a year, given the cost of offsite storage in my area.
I always had at least 2 people (one to steer with the dolly and one to push). I also laid a 2x4 across my parking space to keep it from getting away. Is there any chance you can get someone to help you when you're trying to get it in and out of your spot?
Btw, there is a thread here regarding a DIY, power trailer dolly, I think using a battery powered drill as the motor source. Looked doable. You might want to give that thread a read through. -Denise
IMO, the manually dollies are only good for very light trailers on smooth level surfaces and they have zero safety braking so could be dangerous if not on a flat level surface.
There really is no simple inexpensive way to move even a 320, let alone a 400 safely (at least without a ton of people), unfortunately all the powered movers are a chuck of change.
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
Yay for options, though!
Last update (I hope!). Got the trailer valet after several email sessions with their customer service. They were very helpful and ultimately I chose to buy the 5X which attaches to the tongue (not the ball). It came fully assembled and the mounting hardware is very easy to install as well. The unit itself is heavy, so I have to be careful how I move it (weighs about 50 lbs), but it works very easily on level concrete. I have not (and likely will not ever) try it on gravel or grass. On concrete though, it cranks easily by hand and the brake works wonderfully to stop it from moving even when rolling down a slight incline. I did not end up needing to use the drill adapter I bought, but may at some point. You do have to maintain a bent-over position as it is pretty short, and is indeed tedious if have to go far, but it works.
Thanks for all the suggestions!
Woohoo!
just an possible option on some TV.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Not sure about grass, but the testimonials from @Mouseketab and other users, plus Yannis’ video above were what convinced me that this made sense for my situation. My dealer ultimately decided they couldn’t do the install, and subbed it out to a third party customizer who was pretty pleased with the manuverability when I talked with him yesterday after he’d finished it. Another local non-T@b dealer *does* do installs, so it’s worth dropping Purpleline an email to find an installer in your area. @Mouseketab did her install herself with some help, I think. I’m finally picking up my T@b this week, I’m really looking forward to seeing how this handles in person.
Woohoo!
Woohoo!
I looked at it another way...there’s little to no complaints I can find, and the little I did find mentioned that they were resolved by the company. My interaction with the US division with questions just as a prospective customer, and that of my installer with an atypical install both were positive. We’ll see how it goes over time.
https://www.amazon.com/Happybuy-Trailer-Mover-Electric-Trailer-Jack-Trailer-Jack-Easy-Maneuver/dp/B06XYKHNYM/ref=sr_1_3?keywords=trailer+mover&qid=1556733801&s=gateway&sr=8-3
Also, just a tip, they sometimes list open box units on ebay with a Make an Offer option. Offer them $100 less than what they are asking, they accepted the offer immediately. The unit arrived within 4 days of ordering.
MOUSE-KE-T@B
Harvest, AL
