4 seasons of super light use, and the
Alde with analog panel stopped working on my 2015 S-Max.
I followed good forum advice:
- checked my shore power
- checked the outlet
- checked the 3.15 A fuses on the unit = good
- checked the glycol level in the overflow reservoir
- tried on battery only
- tried on LP gas only
I discovered that my WFCO converter is wired differently than the labels that came on it. (A/C breakers for fridge and A/C are mislabeled, #3 is the Fridge, and #4 is A/C, and D/C battery circuits: #3 fuse (10A) is for lights, TV/Radio, AND additionally the A/C Fan, and the LP detector - that sould have been on 4 and 5) I have no idea if this could have somehow killed the Alde, although it did make me suspicious. Is something else not wired properly?
What is left? That 'soldered fuse', the whole board, or the analog panel? I want to fix this, but I can't solder like Chan or Photomom. Thoughts?
emily . northern ohio . 2015 320s . jeep wrangler
2022 Ford F350 Tremor | 2022 Cirrus 620
I agree with @db_cooper. it might be worth checking that thermal fuse. And possibly hunting down an electronics geek. There are easier ways to fix it than the way I did it, which should work just as well (mentioned in the thread referenced above).
Worth trying, anyway. Let us know what you figure out, and good luck!
@jkjenn, I'd think your battery monitor would tell you what the system voltage is.
I know it notifies you if your voltage gets too low. It'd be great if it would provide an 'overvoltage alarm'!
Of course if the converter spikes the voltage suddenly, the Alde will fry at the same time the monitor tells you about it.
I had never tested the output of the converter itself, they said it may have been putting out 17.6 volts the whole time. It may have been part of the bad batch of 2015 converters, too, who knows?
I was a major rookie back then, Alde switches, frying my first battery, listening to other people on how to back up, etc. Thanks all!
_____________________________
2016 CSS 320
2022 Tab 400 Boondock
2021 BMW X5 45e Plug In Hybrid
