Ah, so you got the email from eTrailer, too?RyanAndLulu said:I am a bit OCD about my battery running low as I rarely camp where there are hookups. I have an early model T@B 400 (2018) with the AGM battery and factory installed solar panels. I also recently moved my trailer to a storage facility instead of parking at my house which means I no longer have a power source to charge the battery (besides a noisy/smelly generator). Has anyone installed a Redarc battery charger?
It does when I am parked directly in the sun... up here in the Pacific Northwest... that doesn't happen all that often :( I was camping in Oregon for 8 days last November and was fortunate enough to use a generator mid trip to charge the battery, but it was pretty low for most of the trip which didn't include using the Alde heat.Sharon_is_SAM said:Does your solar not charge your battery while camping?
Thanks for the input!! I store my trailer outside also which fortunately the solar does keep it topped off... but I live in the Pacific Northwest where it rains half of the year and it doesn't get the full charge that I am looking for.MuttonChops said:Not sure why you want this additional charger. With factory installed solar panels you already have a solar-2-battery charger. You should also have (or can add) a TV +12V Battery line to your 7-pin which will also charge the T@B battery while driving.Is your "storage unit" indoors or outside? I store my T@B outside and have a small solar panel that does a great job keeping the battery topped off between travel adventure.
RyanAndLulu said:Thanks for the input!! I store my trailer outside also which fortunately the solar does keep it topped off... but I live in the Pacific Northwest where it rains half of the year and it doesn't get the full charge that I am looking for.
You are no longer speaking my languageSharon_is_SAM said:I wonder how this compares to simply using a smaller gauge wire for the charge line and 7 pin ground? How high of a current would 8 gauge allow?
#me-no-speak-electrical-talk Essentially, the thicker the wire (smaller gauge) from your alternator to the plug on your TV that the trailer plugs into, the less juice that is lost. Increasing the thickness if your power wire used to be the easiest way to improve power output to the trailer.Sharon_is_SAM said:I wonder how this compares to simply using a smaller gauge wire for the charge line and 7 pin ground? How high of a current would 8 gauge allow?
This explains it better than I could:Sharon_is_SAM said:@jkjenn, how is this device not married to the same alternator output?
https://youtu.be/ITamN84IiAo2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
The Alde hardly uses any power on propane. Also, "pretty low for most of the trip" is sort of vague. How are you monitoring your battery? Can you give us specific numbers on "pretty low?" If you were trying to get a reading on your battery and the battery wasn't "at rest", then it will always read "low".
It is similar. Does not appear to give you an option to use solar, but it is also much cheaper. It might be a good solution!Sharon_is_SAM said:Is this the same thing offered by Renogy? DC to DC charger
Is this the answer to folks running their 3 way frig on battery while towing?
If you have solar mounted on your TV will the BCDC will draw from your solar before your TV (assuming in transit.) It would save extra where and tear on your TV battery and as also keep th in gs go il ng when parked but still connected to your TV. I am hoping my factory solar will help, but this is also a possible solution.Cbusguy said:Not sure why you would want to use it for solar. It is intended to isolate and manage a second battery from the primary. This allows it to be of a different type from the primary, example lead acid tow vehicle starting battery, lithium trailer battery.
Your solar charge controller should be able to manage your trailer batterys.
jkjenn said:If you have solar mounted on your TV will the BCDC will draw from your solar before your TV (assuming in transit.) It would save extra where and tear on your TV battery and as also keep th in gs go il ng when parked but still connected to your TV. I am hoping my factory solar will help, but this is also a possible solution.
It's a good question and I don't know, yet. The MPPPT reacts to the voltage, so theoretically, the MPPT would see the battery voltage and only send what is needed to reach optimal charge.ChanW said:Ok, I'm confused re simultaneously tow-vehicle charging the Tab battery while the roof top solar is connected.
How does the Victron MPPT controller behave when there's a second source of charge being applied to the battery? For example, if connected to the seven pin of the TV while simultaneously connected to your solar system?
Isn't the TV alternator's charge rate going to confuse the controller as to what stage it's in?jkjenn said:If you have solar mounted on your TV will the BCDC will draw from your solar before your TV (assuming in transit.) It would save extra where and tear on your TV battery and as also keep th in gs go il ng when parked but still connected to your TV. I am hoping my factory solar will help, but this is also a possible solution.
jkjenn said:It's a good question and I don't know, yet. The MPPPT reacts to the voltage, so theoretically, the MPPT would see the battery voltage and only send what is needed to reach optimal charge.ChanW said:Ok, I'm confused re simultaneously tow-vehicle charging the Tab battery while the roof top solar is connected.
