Acrid Chemical smell from Toilet / Black tank in 2016 320S
Hello all.  We keep experiencing a strong acrid chemical smell from our toilet / black tank.  It is not a waste smell.  I have cleaned/flushed the black tank (by dumping water/flushing repeatedly) till clear water seen.  We use 1/2 scoop of Happy Camper mixed with water after each dump.  I see lots of happy folks using Happy Camper.  So I'm not sure if its that chemical or something else we keep smelling.  Its definitely coming from the toilet area.  We checked for glycol leaks etc in the other compartments, not finding any smell there best we can tell.  And assuming if it was actually an unclean black tank, it would smell of waste, not the acrid chemical smell.  Any thoughts or suggestions would be appreciated.  We live with it, but would love to resolve the smell issue.
L & L
2016 t@b, t@bitha trim, 'TinyTot'
TV: Toyota Highlander, 'the Buggy'
    Do you keep your p traps in the shower and sink filled with water?  Toilet bowl filled with water.  That will keep the gases from escaping back into the TaB.   Is it possible you are smelling the gray tank if your p traps are dry?
    If checking the P traps does not solve the issue, I think I would flush the thank a few times even though the water is clear, you might have some powder or other caked somewhere.
  • JEBJEB Member Posts: 268
    edited May 2019
    I'd consider adding a biologic to the tank.  You probably have something rotting in there that isn't getting flushed out.  I have had good success with Digest-It when my old trailer's black tank started developing a sulphur smell.  https://www.amazon.com/Unique-Digest-Holding-Tank-Treatment/dp/B07564FPHL/ref=sr_1_fkmrnull_1_sspa?crid=HKJN5D4HXPX8&keywords=unique+rv+digest-it+holding+tank+treatment&qid=1558531171&s=gateway&sprefix=digest-it%2Caps%2C136&sr=8-1-fkmrnull-spons&psc=1.  Don't expect immediate results.  It's not a deodorant.  It takes time for the bacteria colony to build up and start feeding.
  • LeeMLeeM Member Posts: 7
    Thanks Sharon_is_Sam and jkjenn, I'll check better about the traps and water in toilet to be sure.  JEB, I'll think about your note too.  I think this gets to a point I have not been sure about.  Since my smell is chemical, almost a sour chemical smell, and not #1/#2 direct waste type smells, that could still be build up in my tank that I've missed getting cleaned?  I assume that's the implication based on your sulphur smell concept.
    L & L
    edited May 2019
    Yes.  Sewer gas does not necessarily smell like poop.  In my case, the sewer gas smelled like sauerkraut.
    @LeeM use a full scoop of Happy Campers and between that and water in your P traps I bet your problem will go away. I used a half scoop at first and now use a full scoop. I also put a half scoop in each drain with water for the grey tank. Since it’s enzymes it’s not a bad idea. Good luck!
    Then there is always the “scrub the inside of your tank clean” trick! 1/4 fill your black tank with water, and the dump a bunch of ice cubes in and then go for a drive. The agitation will get all the sides & top clean...
    @LeeM, it is recommended that you fill your black tank  full before dumping.  The idea is to prevent anything from clinging to the sides.  So, if only partially full, add water before dumping.  Along those lines, if hooked up to a sewer, don’t leave the tank valves open - only open them when ready to dump.  We use Happy Camper, too, but consider adding Calgon or Borax to both tanks to keep the inside of the tank slick which prevents cling.  Google “Geo Method”.
    adding a water softening agent makes sense
    2009 GMC Canyon,   3.7 liter
    I always add about 2x the amount of wheater if what I am flushing. Insufficient liquid leads to build up.
    (I think the ice cube trick was debunked...  ;)  although it sounds like it would work! There's a video someplace online...)
    We too soften the 'starter' water in the holding tank, with Arm & Hammer Washing Soda, about a quarter cup after each dump, plus about a gallon of water.
  • mrericmreric Member Posts: 154
    use just a bit dishwasher detergent together in the black tank,    our poop does have lots of oil and it clings to the tank the detergent seem to help
    Thanks to all for the very helpful posts.  Tiny Tot is out getting the wheel bearings repacked before our trip to uCamp.  When I get her back, I'll certainly work on doing a better job cleaning, more Happy Camper and likely either the soap or softener.  The chemical smell is what I think was confusing me.  This has helped a lot.
    L & L
    Sounds like you've got a plan! I usually add Dawn dish soap, too. I don't think it will hurt, and it probably helps! Have fun at UCamp! those of us who can't come are grateful for pics and stories!
  • ChrisKChrisK Member Posts: 280
    Agree. We get that every few months. Being in AZ its so dry and the sloshing related to driving causes the p trap to dry out. We pour some water in and it goes away.
    2014 T@b S Max AKA T@dpole
  • 2Cougs2Cougs Member Posts: 927
    We scrape our dishes and wipe them with paper towel before washing in the sink, but sometimes end up with a solid white greasy substance when we drain the gray water... Have been adding lots of hot water with Dawn to cut the grease and that seems to help.
  • johnfconwayjohnfconway Member Posts: 295
    edited May 2021
    We too must have ended up with organic matter residue in "cleaned" gray tank emitting gas. Trying to conserve water with faucets on low flow must give gas under pressure the ability to push past broken water column in p-trap?
    We have been using "Elemonator" in gray tank while in use. Just ordered "Happy Campers". Would like to treat both gray and black tanks with that product. Conundrum is getting both tanks 2/3 full with water. Have never hooked up to hose directly... we only boondock. I know how to get ~20 gallons into fresh water tank using gpm with hose. But do not want to put extra wear and tear on water pump. So direct water makes most sense.
    If hose is connected to pressurize system, then faucet flow rate determines how long it takes to get gray tank 2/3 full? Same is true for toilet flushing and getting black tank 2/3 full? Any tips on how to SWAG this quantity of water using hose and not the fresh water tank?
    2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X  Tucson, AZ
  • webers3webers3 Member Posts: 423
    I had a similar experience during 2 month work camping last summer. Initially I was sure the smell was coming from the black tank, although it didn't smell like a sewage, but by the end of my 2 month camp stay I discovered the smell was coming from the gray tank through the shower drain. I was emptying the gray tank regularly so I couldn't understand why there was an odor. Towards the end of the camping I also noticed that the gray tank level indicator stopped working. I discovered the problem was not being able to power flush the gray tank and during the long stay, the soap scum and food particles stuck to the tank. Before the 5 hour drive home I had filled the gray tank half way with water, added little bit of chlorine and dish detergent. When I got home I emptied the gray tank and noticed the water coming out was gray and full of sediment. The level indicator works again and no more smell. I would start with the gray tank.
    When the trailer is connected to city water, the water lines in the TaB are pressurized from the city water connection, not yiur fresh water holding tank.  Just connect to City Water connection, turn off the pump and run water from the sink and shower to get the gray tank filled to the level you want for cleaning.  Your fresh water tank and pump are not used if you use the City Water connection.  We give our water tanks a good cleaning this way at the start and end of each camping season.
    Yes, got that. With city water I can estimate gallons per minute (gpm) coming out the sink faucet by collecting it in 32 oz. measuring cup and a stopwatch. That will get me the 18 gallons I'd like to get in there for a decent cleaning. I guess with black tank I can keep flushing toilet 'til the monitor panel shows it 2/3 full. Should I let the Happy Campers product soak for a couple of days?
    edited May 2021
    @johnfconway - for the black tank, just open the toilet flush valve and eye ball the fullness of your tank.  If you are trying to get rid of residual sediment and odor, leave it set for a couple of days.  You can also drive around some and it may help, but the enzyme itself will work.
    You can tell when the gray tank is full by watching your shower pan.  I don’t find the tank monitors to be very accurate.  Not sure how the KIB compares to the SeeLevel monitors, though.
    Another thing to do is add Calgon or another fabric softener to your tanks.  It will help coat the sides to prevent anything from adhering.
    edited May 2021
    For the black tank, if you do not have a black tank flush inlet, you can put a garden hose in the toilet, and see the water level rise by holding the flush valve open with your foot.  You will see when it is full.  Joh, your 2020 TaB 400 has the black tank flush inlet, which will fill the black tank very quickly.
    Thank you @Denny16 and @Sharon_is_SAM! I'm on it...
