As I research the various sewer drain hoses I am impressed with the fact that customer reviews on ALL of the available products cite leakage as a common problem.
Whether I look at reviews for Camco, Valterra, or Lippert, I commonly find statements like "it's worthless", "it leaks", "DO NOT BUY!"
Have any of you found that one product is reliably superior to all others?
Does leakage always develop eventually and how might one attempt to prolong the life of a drain hose?
In looking at the reviews for both on Amazon (for example), consider the date of the review. Many are old posts and pre-date improvements made to the hoses and their drain pipe connectors. The same reviews you have been reading almost swayed me away from the Rhinoflex, but I figured out that they were referring to an older version that had a problem with leakage. Mine works really well and does not leak. Also, although there are numerous (older) reviews that say the Rhinoflex will not fit the Valterra storage tube, and that people had to shave off a portion of the Rhinoflex fittings to get it to fit, that is no longer true. Since it has been redesigned, the Rhinoflex now fits that tube nicely. See the following discussion:
https://tab-rv.vanillacommunity.com/discussion/comment/110818#Comment_110818
Beyond outdated reviews, I suspect that some of the claims that a certain product is "junk" is a result of user error and failure to read instructions before using the product. This applies to many reviews, not just sewer hoses.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
British Columbia, Canada
The biggest issue I have encountered is it is almost impossible to thread the adapter into the sewer connection in most camp grounds, either recessed too much or threads full of crud. Most conveniently provide a rock, LOL as the fix for keeping hose in place during dumping.
