It's heresy I tell you....but who needs a spare tire?
13»
  • Luckyj
    Luckyj Member Posts: 286
    We own a T@G outback, but also other types of utility trailers, and I would never go anywhere w/o a spare.
    I do have access to AAA, but I will never count on them to change a spare.  It would take me longer to complete the call than doing it my self.  We also travel at night and some time far away from any towns or service.  All this would result in longs night and very long waiting times.  And on top of this, you are at the mercy of the co pany that comes to help you.  With a spare, you can choose where the bad tire will be fix or replace.
    and I am also among the ones that rearly check his spare, since I have on board air in my wrangler and a portable air co pressor in my other TV.  So often, it is faster to fix the tire than changing it. Some areas will be closed for weekends.
    I also travel by motor cycle, and a flat is always a major inconvenience and can be dangerous on a bike.  This is harder to controle and prepared for.  So since I can be better prepared for car travel, then I do it.
    to me, it is part of being prepeared.
    but this is me and even my GF is not even part of this.  :)
    TV 2005 jeep TJ unlimited
    Alaskan Malamuthe on board!
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    I think the very best insurance is a visual inspection each day before towing along with monitoring air pressure, preferably with a TPMS so low pressure and high temperatures are caught early. Most blowouts don't just happen, they result from low pressure then overheating, then tire failure. Not always true, especially for the notorious China Bomb tires...
    I have had to put a spare on my pickup exactly twice in 19 years and 300k, both off pavement. Zero times on a 14 year old cargo trailer with over 30k miles and my wife has had to call road service a couple of times in 14 years and 150k on her car.
    Some new vehicles have even got rid of the doughnut tires in favor of no spare. I think tires are generally reliable enough these days that the chance of needing to change a tire is rare. Still I have spares, a TPMS, tire plugs and an air compressor. BTW, do not rely on a cheap "tire inflator" , lay down a few hundred bucks for one that will actually be useful when you need it, I can recommend the Viair brand.
    Now to get rid of those China Bombs on my new 400!
  • Luckyj
    Some of those tires that do not have spares, will have run flats tires of a can of gooe to fix it.  But for those who did not know, a run flat tire is done ounce it was used on a flat.
    Call me old school, but for me, a spare is still essentiial, even a simple donut, witch could be use on a T@B.
  • TerryV6
    TerryV6 Member Posts: 1,101
    @texasaubiefan,
    These topics are great.  It’s always good to stir up conversations.  It can get stale around here...
    2016 NuCamp 320 T@B Max S
    T@bbey  Road
    Appleton,  WI
  • Marceline
    Marceline Member Posts: 1,748
    If you try hard enough you can break anything. I blew out two tires at once a few years ago. 🤦🏼‍♀️
  • gspdx
    gspdx Member Posts: 208
    I my 41 years as a licensed driver I have replace a tire on the road once.  But it was out in the middle of nowhere when I lived in Kansas.  But that was on a car and not a trailer.  Could I leave the trailer behind if I had to, sure.  But I will continue to carry a spare for both my truck and my trailer.
    2019 T@B 400 BDL
    PNW
  • db_cooper
    db_cooper Member Posts: 749
    Since I first posted in this thread a couple of years ago, I have a new story.
    We drive a lot of FS roads in the PNW, and I'm up to five flats over 20 years.  If you stick to pavement the OP probably has a case.
    I managed two front flats at the same time last year on our Subaru, with only one spare of course!  Managed to patch the other tire with gorilla tape, 2 cans of fix a flat, and a small compressor.  Would have had to ride 20 miles out on the mountain bike to get help.
    Haven't had a flat on the camper yet, but take it on the same kind of roads, so won't leave home without the spare.
  • Hops
    Hops Member Posts: 53
    edited May 2019
    I did get a flat but it was in town so easy enough to take it off and to the shop for repair.
    BTW - I did find a way to use by tow vehicle spare (Ford Escape) if necessary. Information at this thread:
    https://tab-rv.vanillacommunity.com/discussion/comment/84384#Comment_84384
    Hops and Cascade
    2017 T@B 320 Max S
    2014 Ford Escape 2.0 EcoBoost
  • DigitalSorceress
    DigitalSorceress Member Posts: 213
    A spare tire is one of those things I'd rather lug around than find myself truly stuck. I've got a newer Boondock with the spare up on the tongue and it seems mostly to stay out of my way :)
    ~Tananda
    2019 T@B 320 S Boondock Edge  named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
  • Luckyj
    Was it day time or night time, week of weekends.
    and just for your information, do not have a f'at tire in a small town past 5 pm or on weekends.  Those little gas station with repair shop are not as cmmon as they use to.  ;)
  • RCB
    RCB Member Posts: 249
    In support of texasaubiefan.....the Kia Soul wifey drives has no spare but came with  a can of goo you spray into the tire thru the valve. As long as it is just a puncture you’ve got a chance.
    400 - 2019
    St Catharines, ON
  • Luckyj
    Well, I guess I might have to scratch the Kia Soul from My possible next daily driver. In the location I drive, late night and weekends, it could take me up to 2 days to get a tire fixe or replace.  And it is not even forest roads.  :(
    We purchased a spare tire for our latest car purchase that did not include the spare.  I don't really care what the actual calculated risk is of requiring the spare - when you need it, you need it.  Easy fix and cheap insurance.
  • ChanW
    ChanW Member Posts: 3,165
    edited June 2019
    My son and his family, heading to Vermont for spring skiing, damaged his rim with a bad brake caliper, so had to install the donut spare. Holiday weekend, everything was closed, so no place to find a new rim.
    Drove on the donut to Killington, figuring they'd get it fixed after the weekend.
    Of course, the next day the donut was flat!
    Tow truck had to take them into town.
    Needless to say, I believe in spares!
    (our Tab dealer, Dan Kearney, in Rutland, finally found him a rim, repaired the donut for him, checked the brakes, and got them rolling home, all after a great weekend of skiing. Hardly charged him what they should have. Great guys. Can't say enough about our six-hour-distant Tab dealer!)
  • db_cooper
    @RCB
    Throw a second can in, some gorilla tape and a small DC air compressor if you want to be self sufficient.  Then you have a chance.
    One can won't inflate enough to be useful.
  • texasaubiefan
    texasaubiefan Member Posts: 62
    Seeing how I started this thread long ago, I thought I’d share my perspective.
    I had a blowout going thru Dallas.  I had my spare and was thankful I did.   I learned that when a trailer tire goes, it usually is shredded.   I had relatively few miles on them and the tire guy said the tread life was fine.   The tire just failed.   The good news is no damage to the RV.   In fact it handled very well.  I was doing 60 when it happened.   I had my air compressor in my Jeep, aired up the spare, and Good Sam was on the spot 30 minutes later and I was on my way.   Ended up replacing all 3 tires with Goodyear’s advantage as I didn’t trust the factory tires.   Much better and quieter tires.   Put 5000 miles on them during the rest of the trip.   I’ll provide an update later on my towing experience with my Jeep wangler rubicon unlimited.   It was my first time pulling thru the mountains in Colorado and suffice it to say, it wore me out.
    2017 T@B 320-S, Sofitel (M@bel)
    Mabel is my great grandmother that I never knew.  She took her 3 sons (ages 8-2) on an epic adventure from Alabama to Florida in the 1930's in the back of a pick up truck.  I named my female English springer spaniel after my mother.  Might as well go for broke with the brownie points in Heaven!
    TV: 2018 Ford F-150 Lariat Supercrew
    David & Jill, Houston, TX
  • Slackers
    Slackers Member Posts: 491
    @texasaubiefan thanks for following up on this topic.  So many posters don't. It's good for others to learn from your experience.
  • Denny16
    Denny16 Member Posts: 5,431
    Even though the tires look good and have tread left, older trailer tires are a liability, and can fail when you least expect them to, especially on highway use, in a hot area.  Glad you are OK, and no real damage.  I replace my trailer tires every three years or so, depending on the tire/trailer.  Also, pay close attention to the tire pressure, and keep it at the recommend pressure.  Trailer tires loose pressure whilst sitting.
  • tabiphile
    tabiphile Member Posts: 471
    You won't need a spare tire, until you do.
