My wife and I purchased a 2016 T@B Max S on Friday and we're very excited after being tent campers. We both retired earlier this year and are looking forward to new adventures in the little camper. One item I received with the camper was a long crank handle to operate the stabilizer jacks. I couldn't find a spot to store it, I thought the area under the seat with the passenger wheel well would be fine but it was too short. I searched on here and found a couple of solutions. I decided to drill a hole into the next compartment, add a PVC pipe and a clip to hold the handle end in place. The pictures should be self explanatory but it's a PVC pipe, some metal plumbers tape, six screws and a clip typically used to hold a broom on a wall. We also received a modified socket which allows the use of a cordless drill, which will likely be our default method for moving the stabilizers, but I didn't want to be without the handle should my batteries give out. Thanks to everyone for all the ideas we've seen so far on this great forum.
Mike and Lisa Campbell Springfield, MO 2016 T@B Max S - Sold March 2020
Looks great! I simplified the process on our 400 and use a Camco RV socket adapter to raise and lower the stabilizer legs. This has made life easier and I carry my Ryobi drill with me on all trips.
I simply cut the bar at the first turn so it is straight, then use a 1/2 drill with the stabilizers. Store it in on the floor of the passenger side pedestal.
2016 Outback 320 2024 Ford F150 Supercrew short bed.
I had put a bit of PVC up by the spare tire holder on my Boondock platform.. but Honestly, I use a 19mm deep socket and my drill.. so I've just stowed the handle in my Tow vehicle just in case of emergency.. but it's kind of buried ..
Nice solution
~Tananda
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
@TheDinkods, I purchased a set of very similar clips (in white) a couple weeks ago from Amazon to do the same thing. I had planned on storing the hand crank somewhere in the back storage compartment, but I like @MiquelCamo's idea, so I may go that route instead.
I have the crank + two other longish tools that need similar storage, so a month or so back, I bought an extendable plastic poster tube that fit nicely along the front wall of the rear storage bin, accessible from the outside compartment door. There’s enough stuff in that area, I didn’t bother clamping it. It’s nice to have one spot to put those things without them tangling up with everything else in that compartment.
2019 320s BD Lite, white with blue (“Haven”) 2015 Subaru Outback 3.6r (unsafe 200lb tongue weight limit until 2020 models) 2020 Subaru Outback XT Pacific NW
@VictoriaP, you have piqued my interest. Do you by chance have a photo of where you placed those items. I'm not visualizing in my head exactly how you did that. When you say "front wall of the rear storage bin," are you referring to the wall that runs from passenger to driver side of the storage compartment (i.e., the wall to the immediate right when you open the compartment door and look inside)?
Not very good pics, just quick snaps. Sorry for the mess. But yes, looking in from the compartment door, it’s on the right. And from above, it’s against the front cabinet wall. Holds the crank, the 30” drill socket rod for the stabilizers, and the 24” lever for my Purpleline trailer movers. I think I might use pipe clamps or metal straps to mount it higher on the wall at some point, and just let the handle for the crank dangle down. But for now, I’m just happy not to be trying to pull those things out from under everything else.
The black bands you see around the poster tube are part of a shoulder strap that come with it, and that’s probably the perfect place for the clamps to secure it to the cabinet wall.
Got it, @VictoriaP. The photos are perfect and very helpful. I appreciate you taking the time to do that for me. That is the same area I originally planned on placing my crank, but my camper (same model as yours) is in storage and I started to think that I might hit the Alde tank if I drilled a hole through that back wall. Now, after seeing your photos, and after a closer review of my own photos of the Alde compartment, it looks like it will clear the tank nicely (but I suppose you already figured that out.) I guess I will return to my original plan. I'll probably use the white clip I have to hold the handle up against the wall to the right. Thank you! (Greg)
No need to drill into the Alde compartment, at least on mine. The crank fits fine without going that far (unless you want to, of course.) The poster tube butts up against that divider between the compartments, and the crank is pushed all the way to the end of the tube.
Following the lead of @MiquelCamo and @VictoriaP, I added a short section of 1" diameter PVC pipe to the rear storage compartment of my 2019 320S to store my stabilizer crank handle. While I was at it, I added a separate section of PVC pipe to store my Camco fresh water tank filler tube. I attached the PVC pipe using plastic plumbing hanger strap and I also used the spring grip clip to help secure the crank handle.
I installed a couple of command strip holders and use rubber flex ties to secure it to the command strips by the door. It is out of the way and easily retrieved when needed.
Marc & Janet 2016 T@B S Max (H@banero) - 2025 GMC Canyon Denali - Magnolia, TX
My 2020 T@B 320 has the wall between the passenger seat and the a/c compartment Cut Through with an opening that allows the full length of the crank to simply be laid under the seat through the side cabinet door without modification. Though I am considering a way to batten it down so it doesn't slide where it shouldn't.
Camco RV Leveling Scissor Jack Socket Drill Adapter, Fits 3/8" and 1/2" Power Drills, Works With All 3/4" Hex Drive Jacks (57363) https://www.amazon.com/dp/B001V8U12M/ref=cm_sw_r_cp_api_i_TX8kDb08BY7YS
2021 T@B 320S Boondock, Chevy Avalanche, Happy wife.
Nice solution
https://www.amazon.com/gp/product/B000BQNZLE/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
(I actually have a real one floating around here somewhere...)
