On a couple other forums I watch/belong to, there is a "sticky" thread at the top of the forum. It's titled "What I Did to My ...". I didn't see one here so I figured I'd throw this out here and start it off.
1. I removed a couple of the meaningless stickers on the unit to clean up the appearance.
2. I moved the Yakima wind deflector from the back of the basket(?), to the front of the basket, to act as a wind deflector.
Odessa, Fl.
Please post you MPG gain in the TV mileage thread! 😁
2022 Ford F350 Tremor | 2022 Cirrus 620
Insulated the Pex pipes in the wall behind the shower, that part worked relatively well. Started insulating pipes in the water pump compartment, but not sure that really made any difference. And loosening the screws a tiny bit holding the pump to the wall backfired...it actually seemed louder after that. Going to take another stab at it tomorrow.
Also got to experience the “joy” of overfilling the fresh water tank for the first time and having it burp all over me. At least it was pretty warm out! 😂
What I did...
Topped off the cells on my batteries, in preparation for checking the specific gravity, and equalizing...
PNW
I finally got the shelf installed, in the kitchen cupboard, taking advantage of the newfound space that the trapless drain provides!
(Thank you @GatorEgg!)
- Removed velcro for curved cushions from walls. Now I need almond colored caulk because the tiny staple holes are almost as annoying as the velcro. No pics for that one.
- Installed bath grab handle. Honestly, something along these lines should be stock! (Yes, it’s straight, the camera wasn’t.)
- Installed decorator film on shower. Kind of a pain in the backside, but came out better than I expected. Pics in natural light + overhead, and backlit with bath light on.
Tucson, AZ
"You never know when you're having good luck." ~ Unknown
Both from Amazon.
Film: https://smile.amazon.com/gp/product/B07PFN3B8K/
Grab bar: https://smile.amazon.com/gp/product/B076CDMWNW/
If you search this forum for “bathroom grab handle”, you’ll see what others have used. I went with an ADA style grab bar because I wanted plenty of room to wrap my hand around, and I wasn’t sure I’d get that going with more of a handle style. It’s probably just a matter of preference though.
Install tips...get someone else to deal with it? 😁
The film is fairly simple, clean the glass, cut the film mostly to size, spray with soapy water, stick the film up and smooth with a squeegee. Use a plastic or metal cutting guide (a ruler will work) and a sharp knife to trim the edges. There are quite a few videos on YouTube on how best to apply. It’s a nuisance to get all the bubbles out, but just keep working them towards the edges.
The handle, well. I took off the TV and mount a while back, so I just unscrewed the plastic “tray” behind there and peered through the hole at where the plywood for the mount is attached. Measured several times, then drilled my first pilot hole for the top most screw...no problem. Out of the six screws total, five found the plywood. The last, very bottom one missed by millimeters. I probably should have redrilled all of them at that point, but didn’t. The five are enough to hold it solid even with my not insignificant weight pulling on it, but obviously it would be best to get them all embedded into solid wood instead of just the thin luan.
Tucson, AZ
Final project of the day...magnetic compartment door holder. No more using my head to hold it open! I wanted a fairly unobtrusive position for them, so I mounted them close to the hinge, right up against the trim. Used 3m automotive trim tape, which seems to be working pretty well so far. I may still add screws later. I bought the two pack thinking I could use the second either on the water pump hatch or maybe possibly the front propane/battery tub.
https://smile.amazon.com/gp/product/B01INZ7RY0/
Tucson, AZ
Odessa, Fl.
We have been thinking of those adjustment handles as well. I’ve thought of something like this, if it would work...
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
Odessa, Fl.
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Topped off the cells on my batteries, in preparation for checking the specific gravity, and equalizing...”
I should do that today. Thanks for the reminder. We had a big storm and there is lots to cleanup. Priorities... battery first...
T@bbey Road
Appleton, WI
We kept the Velcro. My wife added appliqués ( I had to look how to spell that one) that are removable if we want to use the cushion back. In the morning I like the extra back support.
You can see them in shower door pic.
T@bbey Road
Appleton, WI
@GatorEgg Would also love to know which bin size you used for the q1000. I wish the old wheeled duffle Weber used to make was still available for these.
Thank you very much. Jody is very happy to solve (for her) a problem with what she calls our devil table. She came up with that, not me. In seriousness, we like it...
T@bbey Road
Appleton, WI
