Hi all,
We are in the middle of a brand new 2019 320s purchase and hope to pick it up this week . (Cant Wait !
It was tricky to find the color scheme we wanted as there are not many 2019's left . MUCH prefer the 2019 interior over the 2020 (but thats a whole other topic !)
Anyway, found the exact one we want with all kinds of great options and the right color combo we were looking for,  from a great dealer close by (well about 3 hours!)
The only option it does not have is the bathroom porthole window that we would have liked .
Is it possible to add the port hole window ?
Assuming we could get one from Nucamp, and find out the exact mounting location measurements the factory uses , I dont see why it cant be done ???
Anyone ever add one of these ?
How about any voiding of warranty stuff ?
Thanks for any opinions  !
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
We all have different preferences, but just wanted you to know that if you otherwise found the perfect unit for you, go for it!
The bathroom window was one of the things I had to give up when an unexpected financial hit pushed me from the unit of my dreams to a less expensive one. When I really looked at the positioning of that window, I realized I’d leave it closed all the time anyway. The only time I wish it was there is when I occasionally notice the lack of symmetry on the outside. Never when I’m inside.
Live without for a while, you can have one added at üCamp in a year or so if you want!
Thanks .......
2024 NuCamp T@B 400 BD, Charcoal / White
2022 Ford F350 Tremor | 2022 Cirrus 620
Clean surface with alcohol. You really only get one shot. Once the tape makes contact do not lift or try to reposition. Press firmly. That’s it. Good luck.
3M 1/4” red backed tape is what came with ours. I did have to apply it myself. You can find it at Walmart and most auto parts stores. An even better choice is VERY HIGH BOND 3M tape. Search VHB Scotch mounting tape on Amazon.
Being an ex-sailboater I guess I have a bias. If I didn't have a window in my 320s and knowing what I know now, I would consider this marine grade opening porthole instead of the T@B stock round window.
Aside from the obvious reason for having a window that opens in the bathroom, it is also nice to have the extra ventilation. Taking a shower, shampooing your hair or just drying some towels or swimming gear. If I could find one the correct size for the existing window opening or even a little larger I would change mine. Here is the link if you're interested.
https://www.defender.com/product3.jsp?name=vetus-pw-series-round-opening-porthole&path=-1|6880|2290158|2290160&id=2147521
Earl & Sue | Central NY |
2017 T@B 320S | TV: Chevy Silverado
I kind of like the symmetrical look of 320 with the bathroom porthole window though . That side looks a little plain without the window .........
While I understand the factory positions the bathroom window to mirror the door porthole, I positioned ours at about the same height, but at the mid pojnt between the window and end trim. It looks great on the outside and, I feel, adds natural light and a greater feeling of spaceousness on the inside. I still have the rotating blind to fit, but rather than adhering that permanently, I plan to use small velcro pads so it can be removed for wiping and cleaning. Feeling very pleased with this easy upgrade!
Question - How much did the window cost ? Was it direct from nuCamp ? (not sure if nuCamp manufactures these windows or another manufacturer ???)
Still thinking I may add this to our 320 .........
Very nice work , although a bit of a nail-biter I am sure !!!
This is something I've been wanting to do since purchasing our 2018 T@b. The dealer had pre-ordered it so there was no opportunity to specify the extra window. The job is relatively easy if you take care and have the confidence to do it. Measure/check, messure/check, then measure and check again!😀
