I will say upfront that while I’m loving this camper already, I think NuCamp has made a mistake with the Air8, and I believe it is undersized for the
[email protected] 400. Bright sunshine, 91 degrees at 1:30PM outside, camper in full sun. The air conditioning has been running for 2 1/2 hours in the
[email protected], all window shades closed, refrigerator is OFF, and the best the a/c can do is bouncing between 78-81.5 degrees. The temperature at the nozzle closest to the unit under the bed is 66.2 degrees; the nozzle above the bed is 67 degrees, and the nozzle up front at the dinette is putting out 68.7 degree air. Nominally a 9-11 degree difference. Should I expect better performance?
2020
[email protected] 400 BDL w/ solar
2016 F-150 4x4 Crew, 3.5L Ecoboost
Middle Tennessee
YNWA LFC
[email protected]@t 2015 S Max Outback, ‘06 V8 4Runner
Middle Tennessee
YNWA LFC
2015 Subaru Outback 3.6r
Middle Tennessee
YNWA LFC
I also have noticed that a posting back in May by @Arizonayeti said his Air8 manual said it had a nominal cooling capacity of 8000 btu, but my manual says 6000 btu. Hmmmmm......
Middle Tennessee
YNWA LFC
I have no doubt that if that AIR8 won't keep a 400 cool in direct sunlight. Makes you wish they did a bit of performance testing before they just make changes. Ours never shuts off during the day, with the temp in the camper set to 78 degrees, just runs and runs.
I honestly believe the owner group is nucamps R&D department and now we have branched out into performance testing as well.
Middle Tennessee
YNWA LFC
Vent temperatures were 60.1 degrees under the bed, 63.4 above the bed vent, and 66.0 degrees at the vent under the dinette. Those outlet temperatures seem reasonable.
So 6 1/2 hours after the camper is out of the sun, the best the a/c unit can do is 79 degrees in the cabin. It sure seems like this unit is undersized for the [email protected] 400, and that is very disappointing to say the least for such an expensive camper. I really like our [email protected] 400, but this new a/c unit is a fatal flaw as far as I’m concerned and makes me second guess our purchase decision.
Middle Tennessee
YNWA LFC
Have you read the FAQs from this website? Scroll down closer to the bottom.
https://www.truma.com/int/en/products/truma-air-conditioning/truma-saphir-compact.html
Basically it assumes that an RV has better insulation than a car and they report that the Air8 will produce a maximum temperature difference of 10 C (18 F) under optimal conditions (RV has been kept cool in the shade, all windows/shades are closed and the humidity is low, warm air has been exhausted). They specify that the indoor vs outdoor temp difference should not be too large and to prevent condensation on the equipment, it is best to close all doors and windows.
How do I cool my caravan or motor home especially effectively?
You can keep a cool head at any temperature by following the tips:
Why does a Truma air conditioning system not have the same cooling output as a car air conditioning system?
In many cases, air conditioning systems are used in cars for just 20 to 30 minutes. A comfortable temperature of about 23 °C should be reached within a very short time. Because cars often have dark colours inside and outside and angled windows, such as the windscreen, they heat up very quickly. This is why car air conditioning systems are equipped with a high cooling output (6 to 8 kW). They are much more powerful, as the compressor of the air conditioning system is driven by the car’s engine. This explains why the engine loses power when the air conditioning system is switched on in the car.
On the other hand, RVs are often used for several hours. The air conditioning system is also used over a long period (while driving or at the camp site). Light external colours and steep windows reduce heating of the vehicle compared to cars. The cooling output of air conditioning systems in RVs is generally much lower, as they are electrically operated and the power supply is limited. This is why a high level of energy efficiency, which ensures optimum cooling output with low power consumption, is essential.
Our air conditioning system can produce a maximum temperature difference of 10°C under optimum conditions, such as when the vehicle is in shadow, is darkened, windows and skylights are closed and humidity is low.
Middle Tennessee
YNWA LFC
water was steady dripping out of the exhaust vent, with what I just read, I am not sure that is okay or not, you would think they would need to drain condensation
not the end of the world, but not stellar performance either.
Middle Tennessee
YNWA LFC
Middle Tennessee
YNWA LFC
Some members have changed the fantastic fan for the Maxx fan which is designed to be open during travel and can be left open during rain.
On my 320 the intake and exhaust are separated by the frame, but I doubt that would matter as the louvers do a nice job separating the intake and exhaust.
I am not sure who made the decision that a roughly 20 degree temperature drop was sufficient for any of the the trailers, seems it wasn't investigated very well.
Interestingly, Truma has a slightly larger version of the one in the [email protected] called the “Saphir Comfort RC”, which is an air conditioner/heat pump combination that is rated for 8100 BTU in cooling mode. The unit has the same width and height dimensions and is only 2.5 inches longer than the ones in the new [email protected]
Also, the ductwork under the bed in the 400 makes a sharp 90 degree bend right out of the unit, and sharply turning the airflow introduces turbulence, that is, friction, thereby reducing airflow.
Middle Tennessee
YNWA LFC
It is possible that the Cool Cat physically would NOT fit under the bed, thus a new vendor was found? It seems that new vendor had a unit that fit, but maybe only because way less BTU's?
I can also understand NuCamp sourcing a single vendor for all models, that makes perfect sense.
What doesn't make sense is a knee jerk reaction to hitch weight without some research and testing. While I like the mostly good quality of NuCamp products, mechanical and electrical engineering seem to be very weak areas. Every design change needs to be considered for what other systems may be affected and not convinced that is happening at an acceptable level.
Middle Tennessee
YNWA LFC
1) "To obtain a healthy indoor climate, the difference between inside and outside temperatures should not be too large"
2) "Our air conditioning system can produce a maximum temperature difference of 10°C under optimum conditions, such as when the vehicle is in shadow, is darkened, windows and skylights are closed and humidity is low."
The first is simply absurd. If there was little difference between the outside temperature and the desired inside temperature, you wouldn't need an air conditioner in the first place. I interpret this as a pre-emptive explanation for an under-performing system.
The second seems reasonable at first blush but things fall apart quickly when you get to the conditions under which the results can be achieved. If the desired indoor temperature is 70 degrees, for instance, that means the system can achieve it as long as the outdoor temperature doesn't exceed 88 degrees. If it's 95 outside, you can get 77 indoors. That's fair. But that's with the camper in the shade, in the dark, with closed windows in low humidity. If the humidity was low and I was parked in the shade, I could be comfortable with a fan. Again, it sounds like they're laying out reasons why it will likely under-perform.
Part of this could be cultural. This is a European system, and air conditioning isn't nearly as common in most of Europe compared to the U.S., so maybe a system with these specs is acceptable there. Witness the marginal A/C in any Mercedes-Benz.
The Cool Cat was a proven performer, but the relatively heavy tongue weight on the 400 compared to the trailer's overall weight was a concern for a lot of buyers, so I can see why NuCamp wanted a different solution without having to completely re-design the camper. What surprises me is that they chose a system with these limitations and only 60% of the BTUs of the Dometic unit.
Not to add insult to injury, but my 2019 400 was sitting in my concrete driveway last week in full sun with the shades open with an outdoor temperature of 88 degrees and relatively high humidity. The temperature inside the camper was 95 degrees as indicated by the digital thermometer that came in the welcome pack. 45 minutes later, the digital thermometer read 68 degrees - a 27 degree Fahrenheit and 15 degree Celsius difference.
Would a computer fan in that duct help at all?
Middle Tennessee
YNWA LFC
So, starting off with a cool camper and starting the a/c early, I only have a 5 degree differential between outside and inside with the camper in full sun. It will not hold temperature starting off with a cool camper. NuCamp has made a mistake with this air conditioner; it is simply undersized for this camper. That’s a lot of $$ to pay for a camper you cannot use comfortably in the summer.
Middle Tennessee
YNWA LFC
