jkjenn
Member Posts: 6,417
Chan or Frank maybe.
Removing the 3-way Norcold refrigerator
I removed and reinstalled my 3-way last summer. I did not remove the stove. The gas
line connects on top near the middle about 6 in. from the front. I was able to slide the
fridge out far enough to get to the pipe connection and wiring before completely
removing the fridge. My gas line is pretty long and can move a lot without causing
problems. The gas line to the stove is pretty much the same story. I disconnected the
vents at the front of trailer by taking off the caps and removing three screws on each
vent. The vent lines are flexible but you can't pull the fridge out very far with them
connected.
I reversed the process to reinstall the fridge.
Duncan
Diane Hammon sadieh79@yahoo.com
On Thursday, February 5, 2015 12:11 PM, "wallflowervintagetab@gmail.com [tabtrailers]"
<tabtrailers@yahoogroups.com> wrote:
Bob, access to the 3Way is mostly through the top, under the stove top. I don't recall
how accessible the gas line connection is in there, but they had to install it somehow.
Be sure you disconnect the electric, 12v and shore power, before taking up the
stovetop. Turn off the propane too...
The stovetop is held in by 4 'toggle' type anchor screws that rotate to their 'released'
position when you loosen the screws a bit. Don't try to remove the screws completely,
you might lose the toggles off the ends of the screws.
It's much easier to do, than to explain.
There are little black rubber caps on each screw head, that also act as the bumpers for
the glass range cover to rest on when it's closed.
HTH
Chan
2014 'S' Maxx
When I undid the screws along the front of the Norcold (piece of cake!) I also removed my screen door. This really wasn't a major deal as the door has a couple of mounting screws holding it in place and one through the bottom door frame area and you basically just pull the door up (there is a screw on each side of the frame that serve as keepers of sorts for the door) and out carefully. You will see the mounting grove opening and small track that is cut into the plastic side wall portion of the frame of the screen door should you decide to remove it.
I also had to remove the stove top as this needs to be done to get to the propane line on the fridge (which you need to unhook) and this really wasn't a major issue either as my stove was held in place with four corner-screws and when removed the stove lifts out easily and I was able to do so without unhooking the propane line.
Note - The Norcold unit WILL NOT budge after removing the front screws along the face of the unit, etc. and WILL APPEAR to be held in place by clips, etc. but it is definitely not..... The vent piping is solid steel and holds the Norcold in place like the rock of Gibraltar!
The biggest issue in this entire task relates to the front fridge exhaust vents on the front of the trailer. It's VERY EASY to unscrew the vent screws as this will now release the Norcold unit (it almost gives off a sigh after unscrewing the vent screws! - Just kidding!) and allows you to easily slide/remove the Norcold unit out from the cabinet area. However when it goes back into place, this is where all the fun begins. Aligning, fastening and screwing the Norcold unit back onto the vent pipes is a swift pain in the butt and I will admit that a second helper on site (would be an enormous help) might have helped out some and allowed me to get the venting installed much easier.
For one thing I could see from the factory's initial Norcold install that the screws did take them some time to install and mount the Norcold unit flush against the vent pipes. One of the front screws was off on a slight angle so I ended up struggling with it until I got it back into the proper alignment and after alignment was made I was able to screw the exhaust piping in place tight. I also had to open the trailers front window, reach in and use my arm to pull the unit into place, get both ends of Norcold piping aligned with the screw threads and secure the Norcold unit into place once and for all. This can be accomplished, but this area is a tight fit, the piping is rigid and there is no give to it and this portion of the task requires patience, proper alignment, some precision and some stamina.
As noted above, you will scratch your head in frustration if you think the Norcold unit is easily coming out in the initial phase of unscrewing it from the front of the cabinet as there is a bit more to this task than that.
Mike, hope it's the only gremlin you have. Then infotainment system in mine has a condo of gremlins living it in. I think they have parties in there at night. That might explain all the Starbuck and Dunkin Donut snack bags and coffee cups.
I also found a bad ground wire on one of the circuits in the bench, repaired that and things seem to be fine as I took the truck and trailer out last week on a 20 mile test drive and the bell irritant seems to have greatly subsided. The only time I got the bell was when I exited the freeway and was making a left-hand turn. For what we endured previously this is about a 99.9% over all improvement and I cannot complain.
You bring up a good point with the information above as I'm certain my 16 Silverado has the same sensors built in as I do have the safety package and over course the seat vibrates when I am backing up or getting in close to the garage wall, etc. That is something additional I will consider and try the next trip out next week. I've always felt that with the enhanced software systems on this vehicle it might just be over sensitive and pinging the bell randomly. It would seem to be a ground issue or something between the TV and the trailer, but since the trailer is interconnected through the trailer harness and the electric receiver on the truck the old ground through the ball of the hitch theory no longer applies here. And with things like electric brakes, Norcold wiring, tank monitoring system, Alde, trailer side lights, etc. it is like finding a needle in a haystack so far as trouble shooting the electrical system, that also is concealed behind walls, the ceiling, etc. You get my drift here!
http://www.roadtrucker.com/engel/engel-12-volt-acdc-refrigerator-freezer.htm
I had been thinking of a cheap $585 small Amazon Danfoss based unit like:
https://www.amazon.com/dp/B07TJ35L3V
since I don't refrigerate much food, and could use the extra storage space as part of a coffee bar, but maybe fully using that space down to the floor for the fridge / freezer with new fans and ducting might improve eventual resale value.
Does anyone know the dimensions of the Norcold 3163, either I am blind, or just can't see, but I can't even find that in the Norcold manual.
I think that included capping off the unused propane line.
We're thinking of taking the bottom part off and having the choice of 4 drawers, or two drawers and the mini fridge, depending on the nature of the trip. And then building a slide-out coffee stand at the top to protect the underside of the stove, so we can finally make breakfast and latte art at the same time.
