Hey folks, I am moving into winter here in the NE and I just discovered that my Alde reservoir isn't holding the glycol and therefore my heating system doesn't work. I have not been able to find where the fluid is going as I do not see any pooling anywhere. Does anyone know where the leak maybe coming from? I am hoping to solve this before the temps drop below freezing!! Thanks!
0 ·
The three tubes that go through that larger black pipe depicted in your photos are overflow/pressure relief tubes, (e.g., when the glycol tank is too full, or the hot water tank has too much pressure.)
What is of interest to me is that, if I see what I think I see, it looks like there is wet areas around the large black tube (i.e., the area around that tube is damp.) When you look at the Alde compartment inside your camper, is it wet around that tube (the one that has three tubes going through it), or has one of the three overflow tubes popped out of that larger tube?
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Are you sure it is not leaking at the Alde glycol tank/reservoir itself? Probably not, but worth re-checking. If it is currently empty, I would suggest refilling it and see what happens. Maybe do that and then run the Alde so the glycol heats up. Maybe the glycol is getting too hot and is overflowing through the overflow tube?
I wonder about adding a bit of radiator leak detector to the system. Uses a uv dye and associated flashlight to find difficult leaks. You would need to flush it good after repair.
It seems to me that if the system is low on glycol, the best time to check & add more might be when it is still hot after running for a while, then turn it off & add to the expansion tank so it can suck it back in as it cools. If it sucks it all back in, then you might need to repeat adding/cooling. I just went through something similar with a car leaking coolant.
Also, you might want to check to see if you can detect whether the Alde circulation pump/fan is working (including fuses on top of Alde). Maybe you can hear or feel it. Some have a switch on the pump with speed settings too.
I seem to recall that someone once said that setting the speed too high could make the fluid bubble up & overflow from the expansion tank. I believe a low setting like 1 or 2 is normal. And if the pump is not circulating the glycol to dissipate heat, then maybe it could overheat it & blow some off via the overflow tank?
It appears that you have a T@B 400, so I am not sure where yours is located. On the T@B 320S, it is located inside the rear storage area at the far rear passenger side corner. It is in a bend in the rubber hose (just as depicted below) and not far from the rear convector (the metal fins that look similar to a radiator.) It could be loose and leaking glycol. If so, the glycol stain should be very evident in that area, but it looks like you might have that black flooring option (I can't recall the name of it), which may make it hard to see a leak. Regardless, if the bleeder valve/screw is loose, turn it clockwise to tighten.
The valve/screw may be hard to see if it is tucked away, but look along the black hose on either side of the convectors. Maybe someone with a T@B 400 can help with where it is located.
P.S. @falcon1970, GREAT tip re the UV light! That would really help in locating a glycol leak on dark flooring.
P.P.S. @Todd77, take a look at the following thread. It is a discussion about the flow assembly mentioned by @Sharon_is_SAM.
https://tab-rv.vanillacommunity.com/discussion/comment/117156#Comment_117156
