Recently discovered my TAB 400 Boondock Lite heating menu has an item of Underflooring heating....didn't know this.
So does that mean a portion of my heat comes from under the floor? Must be....yes? Main floor & bathroom?
Also the menu has an option of continuous or delayed (which is adjustable) for the underfloor heating. What does that mean?
Can not find any instructions or directions.
Anyone know more details?
Thanks.
2019 TAB 400 Boondock
0 ·
https://tab-rv.vanillacommunity.com/discussion/comment/108792#Comment_108792
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
There is not installed radiators for floor heat although the Alde has support built in.
Exactly! The Alde system is built for many different uses--not just the TABs. On the plus side, if you are so inclined, you can add a plethora of additional functions and the control panel will handle them all--assuming you install things correctly.
Hamburg, NY
Hamburg, NY
