Hello folks,
It seem from what I can tell that the users manual might have some bad information in regards to the Battery Switch so I have a couple of questions....
When the battery disconnect switch is disconnected, are you getting power to...
1. The trailer 7 way power feed to charge the battery.
2. The factory solar option to charge the battery.
3. More importantly, will the breakaway brakes function?
Basically does the battery disconnect switch basically disconnect everything?
For Towing, i'd obviously want the battery in the T@B getting charged from the car's alternator. But also for storage when its sitting outside for a week at a time I'd want the solar panel keeping the battery topped off as well.
Breakaway brakes, while 99.9% of the time they aren't going to be used, but certainly that one time it might actually breakaway i'd certainly want that to function as intended...
0 ·
Springfield, MO
The T@B manual is always a work-in-progress as many changes and additions do occur during each production year. nüCamp is a small enough company that many changes are instituted during the production year to add features.
In the meantime, I did contact NuCamp this morning with the details of my trailer and this is the quote from an email I received... "If the car comes detached from the trailer a wire that goes from a little box on the tongue to the back of the tow vehicle will pull a little pin out and activate the the emergency brakes. The battery disconnect switch will not affect this".
Obviously, I wasn't satisfied with that answer so I asked. "...since the emergency brakes are electric, where do they get their power when the trailer becomes disconnected from the tow vehicle? Is there a separate connection to the battery that is not effected by the disconnect switch?"
I'll post any additional details I get from NuCamp and I will be testing mine to ensure I really have emergency brakes. IMO, if the disconnect switch does indeed "disconnect" the emergency brakes a warning should be visible near that switch. If I find this is true, I will create a label so the next owner doesn't tow the trailer, as I have, with the battery off thinking I have emergency brakes.
Springfield, MO
I then went out to my trailer, pulled the cover off the junction box, took my meter and verified that the battery disconnect switch must be "ON" or the emergency brakes have no power. Thanks for your help and your patience.
I am disappointed that you can easily bypass a safety function such as this unknowingly. I'm suggesting this be the first thing to tell any new owner. I appreciate this forum more than ever.
Springfield, MO
"Yes the emergency brakes are electric and they are powered by your battery. However, the emergency brakes are hardwired directly to the battery so the battery disconnect switch does not affect the function of the emergency brakes."
Springfield, MO
Springfield, MO
Springfield, MO
Don't forget to reinsert the breakaway pin after this test as the brakes remain energized until the breakaway pin is reinserted.
After reading through this discussion, I decided to spend some time checking the wire connections at the junction box under the front end of my 2019 320S Boondock Lite. Other year/model trailers may vary from what I found, especially if they do not have a battery disconnect switch. However, on my trailer, I was able to confirm that IN THE EVENT THAT the trailer and 7-way electrical connection should become detached from the tow vehicle while towing, the trailer battery MUST be connected and the battery switch MUST be "ON" for there to be power available to the electric brakes.
[NOTE and a WARNING: You will have power to the trailer electric brakes, even without a battery, as long as the 7-way plug is properly connected to the tow vehicle. HOWEVER, you should never tow the trailer without the battery connected. The whole idea is to have a power source available to activate the trailer's electric brakes in the event the trailer becomes detached from the tow vehicle while towing. It CAN happen, so don't take chances!!]
Below is a wiring diagram of my junction box, plus photos of the junction box and the interior 12V (DC) ground wires bus bar.
As depicted in the wiring diagram, the seven-way plug wires (from the tow vehicle connection) enter through the lower right corner of the box. The emergency breakaway brake control wires enter through the lower left corner of the box. The wiring back to the electric brakes exit the box at the same lower-left corner. Additionally, there is a ground wire (white) that connects between terminal #7 and a ground lug located just outside of the lower-left corner of the junction box. (I learned from @klenger that the purpose of this particular ground wire connection is to make the chassis the same "voltage potential" as the negative side of the battery. He informed me that no current actually flows through that outside ground, because the common ground point for all 12V (DC) systems is the inside ground bus bar - - - see photo below.)
The terminal connections identified in the diagram are as follows:
#1 - Electric brakes.
#2 - Right turn and stop light.
#3 - Tail and marker ("running") lights.
#4 - Left turn and stop light.
#5 - Back-up/Reverse lights (none are present on my T@B.)
#6 - 12V (DC) connections. [Battery cut-off switch is b/w #6 & battery.]
#7 - Ground wire connections.
The 12V wiring generally enters the junction box from the bottom openings and those wires connect at the bottom of each terminal. Wires that continue on to the trailer 12V systems (including the 12V battery and WFCO Power Center/Converter) generally connect at the top of each terminal and exit back to the trailer through an opening in the upper right corner of the junction box. For example, for terminal #3, one green wire from the 7-way plug attaches to the bottom of the terminal; from there, two green wires (one for each side of the trailer) continue on to the trailer electrical connections for the right and left side tail and running lights.
As depicted in the above photograph, there are at least five ground (white wire) connections to Terminal #7:
Green Arrow - Ground wire from interior ground bus bar.
Brown Arrow - Ground wire from Seven-Way plug.
Red Arrow - Ground wire from exterior ground lug (yellow arrow.)
Blue Arrow - Ground wire from the trailer electric brakes.
Not Visible - Ground wire from the trailer 12V battery.
If you look at the blue arrow, you can see (just to the left of the tip of the arrow) the black wire from the electric brakes, which leads to Terminal #1. Because the wiring is so tightly fitted, I could not visually 100% confirm the connection to Terminal #1 without unscrewing the terminal. I elected not to do that. However, it makes sense that it goes to that terminal, because it is the only way the electric brakes would get power from the tow vehicle when the tow vehicle brakes are applied.
Also, as best I can visually determine (without removing the protective covering over the wires), the blue (curved) wire that is connected to Terminal #1 (which you can trace back through the lower left corner of the junction box), presumably connects at some point (out of view) to the black wire from the emergency breakaway switch. In the above photo, you can also see the red wire from the breakaway switch, which enters through the lower left corner of the junction box. That wire leads to Terminal #6, which supplies power to the emergency breakaway switch. Further, if you look at the left-center of the above photo, you can see a red Romex-like wire covering. It contains two wires, which connect between the electric brakes and the junction box.
The above photograph depicts the inside ground wire bus bar (silver), which is the main common connection point for all of the 12V (DC) system ground wires. The bus bar is located adjacent to the WFCO Power Center/Converter. In the photograph, the wire that curves upward is the ground wire that connects to Terminal #7 inside the junction box. (NOTE: the actual connection point for this wire likely varies with each trailer since it can be connected anywhere along the bus bar.)
Finally, if you look at the lower left corner of the above (third) photograph, you can see the bare copper wire that is the main ground wire for the 120V (AC) system. That wire originates inside the WFCO Power Center and connects to the trailer's metal chassis below the floor. Per Creed at nuCamp (11-14-2019), that bare copper wire is also the MAIN ground connection for the trailer (per RV electrical code) since the 12V (DC) systems ultimately connect back to and run through the WFCO Power Center.
Springfield, MO
Odessa, Fl.
2025 Toyota Tundra / Nashville, TN
The fuse for the Trailer Electric Brakes in located in the Tow Vehicle.
That is standard on all trailer brands/vehicles.
The 'Brake Voltage' comes to the trailer via the 7-pin connector, then connects to the trailer brake circuit at the trailer junction box . . . there is no fuse in/on/at the trailer.
The 2019 Honda Passport Owners Manual page 632 states the fuse is located in the Engine Compartment Fuse Box, fuse location 3 "Trailer Brakes 20A"
Your Passport electric brake controller is aftermarket not factory installed. Honda includes a connector under the dash for an aftermarket controller.
That connector is wired to the Fuse Box fuse 3.
Passport OM pages 443 & 444 example the connector usage.
