Hi, I joined the group today, nice to meet you. hope I’ve not started a conversation that exists, but I could not find one. We are picking up our new Tab 400 in two days. I was wondering, as I’ve been told two different things, if the side panels have a plywood core and are also coated with Azdel or if they are free of wood completely. I am hoping that NüCamp has done something to avoid the fiberglass over wood delamination issues of other manufacturers. One dealer told me the outer layer of the side walls was fiberglass, and the roof was Azdel, but some sources imply the entire exterior is Azdel. Thanks in advance!
T@B 400 2020
0 ·
https://www.youtube.com/watch?v=yAqjQGHSDb8
February 2019 (T@B 400) - - may be the same, or very similar, to the above video:
https://www.youtube.com/watch?v=LRTITJw0QiI
June 2018 (T@B 400):
https://www.youtube.com/watch?v=lBDgzCYjxZM
June 2018 (T@B 320):
https://www.youtube.com/watch?v=goJTMwQXVLU
Factory Tour (January 2019):
https://www.youtube.com/watch?v=WVUkSDVYcwM
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I got the flash drive when I purchased the 400 six week age but it looks like the same 2017 manual that is online.
The user written manual is a good resource and I would get that and from the two you will have about all the written documentation.
Will one of our resident experts post a pic of this azdel sandwich for @l@missstsomewhere? Thanks in advance.
The location of the other holes are consistent with the kitchen sink drain, toilet, and shower drain (largest hole.) When I zoom in on the labeled hole, I can see the open end of a black PVC pipe, but I can't figure out what it is for. Assuming the photo is of a 2018 320 S, it would seem that the hole is located in an area that is outside the shower pan, and presumably outside the kitchen cabinet as well.
Just curious..............there is probably a simple (duh!) answer, so go easy on me.
Those pipes are black PVC - - - same as the pipe opening that I labeled with a red arrow in the first photo. However, as depicted in the photo below, the kitchen gray water drains downward via the pipe labeled with a yellow arrow, and any gray water gases vent upward (small vertical green arrow.)
The black water tank (right side of the photo) vents via the pipe labeled with the longer/vertical green arrow. The gray and black vent pipes join together in the upper right area of the photo (connection not visible, because it is behind the wood plank, which is there for structural support and to secure the water pump.) Both pipes ultimately vent through the driver side wall of the trailer (horizontal green arrow.)
Placement appear to be near/under/at the Kitchen-2-Shower Wall.
Have seen "the hole" in other factory pictures so it's not a build error.
Wall placement vs known 'drain holes' . . . .
Adventures: 52 Nights: 329 Towing Miles 41,900+
My only knowledge regarding where the wires enter the trailer cabin is that they are routed through the floor adjacent to the black water tank (inside the compartment behind the toilet.)
The labeled photograph below was previously posted by @ScottG. The green circle is the entry point. The pink circle identifies where the wires travel through a similar black PVC pipe (conduit/raceway) to route them rearward to other locations inside the trailer.
@ScottG only referenced the wires coming from the front exterior electrical Junction Box (because that is what he was working on), so I do not know if the tank sensor wires were in that same group. However, IF the tank sensors wires do enter at the same location, that tends to indicate that the mystery hole is not for routing wires.
** First running a ground wire replacement.
Second time attempting to add a wired current shunt signal cable (ended up drilling a second port)
As depicted in the photograph, the previously unidentified hole is where the shower water ultimately drains to the gray water tank. So, my confusion was in not realizing that the shower floor drain, which connects to a P-Trap, is connected to a black PVC pipe that empties into the gray water tank (red arrow.) Thus, the shower requires TWO holes through the floor.
Mystery solved, and good to know info for future reference. Thank you working through this with me.
