To anyone who has added two 6V batteries to the 320-S. Are there 6V batteries that will fit in the existing tub without doing modifications (except of course removing the 12V)? OR is it possible to mount the NOCO dual 6V GC2 box on the wing and wire 2 6V batteries there?
https://tab-rv.vanillacommunity.com/discussion/5369/help-mounting-noco-battery-box-for-the-two-golf-cart-battery-mod
https://tab-rv.vanillacommunity.com/discussion/6293/6v-batteries-fit-in-outback-propane-tub
Odessa, Fl.
Without moving the propane tank I doubt it would fit. In another post someone moved the mounting for the tank to fit two 6v batteries side by side. I could not get them in my T@B without a tray with the stock tank location. Ask him to send you an image of the installation.
One problem is that the Tab front end is sloped, and makes it so the battery can't tuck up tight to the back edge of the box.
I wonder if he's using a smaller battery than the standard 220aH GC battery.
Also, I'd worry that the batteries, and propane tank, being squeezed together in there, might wear badly against each other, or maybe crack the battery case, when bouncing over those bumps.
Just some thoughts...
Odessa, Fl.
2019 320 Boondock Edge - Sold Jan 2022
2 Costco Interstate GC's fit perfectly in the Outback tub. 3 years since I put them in, they are doing fine. I keep a piece of foam over the top to reduce the likely hood of shocking myself.
They are snug against the propane tank, so I have to take the tank out first to remove them.
2022 Ford F350 Tremor | 2022 Cirrus 620
