Don't let this happen to you - taken from the web:
How it happens -note the jack embracing the trail:
Note: this can happen on the street to
The fix:
After hitching, the jack is cranked down, twisted and removed:
Note that the placement of the Jack-e-up conflicts with the tire support framing.
We through bolted thru steel tubes cut to length above our Lock-n-roll coupler to allow the device to mount:
Note: due to the superior engineering of the Lock-n-Roll system, the safety chains are superfluous and we no
longer let them drag on the trail. However, we add them back when we air-up to appease the authorities.
Removed from the TV, the Jack is extended to engage the device above our Croft 10" Jack wheel
CHEERS!
California, USA
Thanks! The lock-n-Roll was added shortly after we got the trailer - preempting the sad stories I herd about a 2" ball and NuCamps good, but constraining coupler. Unfortunately, I waited till I bent a Jack to order the Jack-e-up. Fortunately, trailer jacks are $60 cheep, but getting home with a bent one requires too much time bonding with a bottle jack. - Cheers
Looks like a good solution. A little cutting gets you to the same place my longer bolts produced.
Tampa FL
I typically do fin by just pull to a non sloped area releasing the coupler but moving the T@b very slowly into place. It is more about not having weight forward on the hitch than being perfectly level.
Wasn't the M416 was a Vietnam era Military Jeep trailer? Do you still have it? You're right that most T@B owners don't need a Lock-n-roll hitch; but when I saw Mandy's video showing NuCamp coming up to hers with a jig to lift her 320 up to replace the frame, I vowed to get one prior to attempting any 4x4 road in my Boondock tougher then a well graded one. 4X4 experience does tend to change one's prospective. I've hitched my TAB on a steep slope that I couldn't have with a ball. However, your method sound's like good advice for a ball coupler though. The Jack-e-up compliments the set-up to.
The reason I ask is I have a 400 and don't plan to convert. I do plan to go into more remote areas but will just be getting more off the beaten path this year. I don't think I will be going as far as @Cherokee but still it only takes one dry creek bed to complicate a perfectly fun drive!
When I lived in Utah I had a pop up camper and I camped with people that had big trailers and they dragged those things into some unbelievable places. Nobody ever worried about that. The all had standard balls with WDH setups and I can remember following them up some really serious mountain forest roads and watching the trailers sway back and forth and wondering when one was going to go over on its side!
PNW
PNW
I sold it when I bought my T@b. 😁
I stuck with the Pintle hitch but either the Max Coupler or the Lock and Roll would have been better choices.
I sold it to a guy outside of Akron back in 2014.
Funny story about the rooftop setup: my first night in it was on the beach at Lake Erie.....during a windstorm....the whole Jeep shook all night. Although I felt plenty safe, it was loud!! I barely slept.
My first night in the Tab was in a windstorm with 70 mph gusts. Stabilizers down and tail into the wind, that thing did not move. Good thing I sleep with earplugs though.
While EVERYONE has a 2" ball on the back of their Pick-up, very FEW people have an off-road hitch. I have a few links before a master link on my safety chains. I remove the rest so a person can't grab the chains an drive away. In addition, I lock one of my wheels. I've been all over the USA in the last 5 years - no theft
