I have a Tab 320 S, 2019. I usually leave my tongue wheel on when camping. Should I? Or would it be better to remove the little wheel and place a block to stabilize? Is there a concern that keeping the wheel on would cause breakage to the wheel if left on when camping?
0 ·
The jack and wheels support the weight of the trailer, the rest is just stabilizing to keep the trailer from bouncing on its suspension when you are inside.
When not using the wheel, I just set the jack post directly on the 2x6 wood blocks.
I use the wheel and this
Tampa FL
2019 320 Boondock Edge - Sold Jan 2022
On the other hand, if you put a big block underneath the jack tube instead, you can save yourself some cranking.
PNW
San Diego, CA
www.airbossone.com
