The user manual shows an expansion tank used to determine the glycol level and to top off the system with glycol. For the life of me I can't find such a tank. Searched the forum, went to YouTube and to Alde website and no dice. Can anyone tell me where the elusive expansion tank is supposed to be?
0 ·
This is not at all, intuitive. In the rear of the T@b, behind the bench set and below the overhead cabinets is a little shelf. There might be a thumbhole in it. You have remove the screws that are holding it down. The tanks is on the drivers side in that little area.
This thread has some good tips re: removing the shelf.
Once again I would like to thank you jkjenn for helping me with this as well as all the other T@Bers who have shared their hard won wisdom here for we newbies to learn from.
Has anyone with a recent T@B managed to find it?
I did find it. You have to remove the side panel (teensy square head screws). Heaven help me when I have to add fluid.
The level is right at minimum so looks like I should order some.
I'm using one of those mirrors that is magnified on one side and normal on the other side.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Once you manage to find the expansion tank, marking the "Max" and "Min" lines with a sharpie is a big help. In addition, the Century TF fluid will fluoresce under UV light. That makes checking the level a lot easier. Lowe's carries a Craftsman UV flashlight.
I did contact Tech Support and they emailed me back with that information. I found the panel. My panel only has two screws at the bottom holding it on covered by the plastic buttons. The plastic buttons threw me off when I was doing my search. my tank is filled almost full with glycol and it's impossible to read the max and min lines as they are on the side of the tank facing the front of the trailer and you can't get your head into that space. I can feel them with my hand but can't see them. might have to try a mirror. in any event, the glycol is a little above the max level I'm sure. Hope that's OK.
It's cold here in North Central PA and I turned the Alde on via electricity and warmed the camper to 60F. The tank got pretty warm. I expect that's natural.
A side note on ergonomics: Nucamp uses screws that require a square screwdriver, not something in most toolboxes. I happen to have one that fits, but NuCamp has also chosen to use different sizes of same nonconsumer-friendly square driver in other locations, including back panels. I will have to put on a mask and brave my hardware store to get behind those if that's where the tank is.
Edited for photo size.
Anyway, @BywaysNW discovery just re-enforces my wish NüCamp's newer models had Cassette/non-Cassette toilet options. Continue to strongly dislike these two piece porti-potti solutions - - really hope my present unit lasts for decades.
Adventures: 51 Nights: 322 Towing Miles 41,200+
