Our 2015 entry door has always swung freely, but since we got back from our last ski trip a few weeks ago it's gotten very stiff to open. Like so stiff it feels like I'm going to break something if I close it. It appears to be the top hinge, but I can't find anything wrong. It was working fine when we got home and unloaded. I raised the stabilizers to see if I was somehow torquing the body, but no effect. Sprayed a little lube in there, but it's definitely an impingement issue. I guess I'll wait to see if it acts different at different temps.
I'm not sure what I'll do if it doesn't get better. The hinge is riveted into the door frame, screws on the door side. The pin is pressed in, but not sure how hard to remove and straighten if bent. Anybody else had their door act up?
San Diego, CA
www.airbossone.com
2022 Ford F350 Tremor | 2022 Cirrus 620
I don't see how that pin could have been bent. As you can see in the photo, the hinges are pretty robust. When you get a chance, check that the screws are all tight and the hinges are properly aligned. The problem may not actually be the upper hinge. If either or both of the other two hinges are loose that may make the upper hinge "bow out' as you close the door.
Looks to me like the only adjustments are on the door itself. The hinge mechanism is held to the frame with four rivets and two screws. Check the two screws holding the hinges to the door. All three hinges should be evenly aligned on the door.
Wow, who'd a thunk it! But that raises the question of what else has the salt gotten to?
It helped, but door was still super loud and hard to swing. I was pretty sure it was the bottom half of the bottom hinge, so I disconnected it from the door and sure enough, door swings free and that part of hinge is super stiff.
I tried a heat gun, tapping the pins and hinge to no success.
So the temporary fix is to push the bottom part out of the way and tucked under the weather stripping, and rely on half of the hinge. I'm It's still plenty strong for this light of a door. I guess I'll replace it if the other half fails, but it requires drilling out the rivets so it will be a pain.
Here's what it looks like:
And here's the top good hinge
Funny you should say that, there's a missing one on the functioning top hinge, but the bottom looks ok.
I tried tapping every direction and no change. The pin appears to be mushroomed on bottom, so it would have to be cut. More work than I want to do until I have to.
