Is it possible to remove or lift the ABS trim from the top of the trailer? If so, how would this best be accomplished? The application would be to use the area underneath as a chase for cabling (trying to keep minds active during down time...).
2019 320 Boondock Edge - Sold Jan 2022
0 ·
You can Run Wire just by pulling up on the ABS, it bends some, should be able to get a 1/4 inch or so space for inserting wire.
I've pulled up on mine - - while researching how to fix a gap.
Note: Unknown if the new yr-2021 ABS can be pulled up this way.
2022 Ford F350 Tremor | 2022 Cirrus 620
thanks,eric
2019 Jeep GC 5.7L
and two furry bed hogs
Colorado
