So I see the Weber Q gets a lot of love from campers.
Any other popular grills being used by the T@B crowd?
The Coleman Roadtrip seems to get good Amazon reviews (for what that's worth)...Anyone using it?
https://www.amazon.com/dp/B07BLFRT4H/ref=emc_b_5_t                2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000
0 ·
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
I do need to decide between compact like the single Coleman Fold N Go and larger but very capable grills like the Weber Q and Coleman Roadtrip. We do cook almost all our meals, so I'm leaning towards the Weber Q1200 or Roadtrip 225 as the best compromise between size and capability for us...but truly undecided at this point.
Thanks again for sharing your experiences, it's very helpful to hear.
-Chris
Odessa, Fl.
https://www.cuisinart.com/shopping/outdoor-grilling/cgg-180/
Golden, CO
2022 Ford F350 Tremor | 2022 Cirrus 620
We cook a lot of our meals and I think/hope this grill, with options like the griddle, and the in-between large and small size and reputation for pretty even cooking will serve our purposes well. And we'll be carrying it in the bed of a pickup, so we shouldn't have issues with odors.
I'm going to start off with out the stand, since I'll be carrying a folding table, and see how that works for us.
Thank you all again for your helpful insights!
That is a bargain (lists for $37 on Char-Broil's website. And it gives you 11K BTU stainless steel burner to boot! Good find!
The Napoleon looks like a nice choice too. What do you see as its pros & cons compared to the similar seeming Weber Q?
2019 Tacoma
I looked at those as well. They are very nice, but are really a griddle, not a grill (open flame). All depends on how and what you like to cook. So many good choices.
2013 Tundra TRD 5.7L
Massachusetts
Tampa FL
For camping, we have a little Weber Q that I picked up at GoodWill for $9 and a Coleman Road Trip, along with a Ninja Foodi Grill (electric).
That doesn't count the smoker, Big Easy, Weber full sized grill and the pizza oven all sitting in the screen room at home!
Tampa FL
I have no idea what you mean about "THE LOOK"
A Weber Q for $9 is a seriously good deal, even if it needed a new grate.
I don't have your arsenal of grills, but one of my very favorites of all time is my Blackstone Pizza Oven...that thing is seriously excellent.
https://www.amazon.com/Blackstone-Outdoor-Pizza-Oven-Cooking/dp/B00CELFJ4A
https://www.homedepot.com/p/Monument-2-Burner-Portable-Tabletop-Propane-Gas-Grill-in-Stainless-13742/311737525
Nissan Frontier PRO-4X (4.6 liter automatic)
Roof mounted solar panels
https://blackstoneproducts.com/collections/griddles/products/tailgater-combo-griddle-grill
Huntington LI
I'm using the new-for-2021 external gas connection at the back of the T@B. Since this connection is after the T@B's pressure regulator, it is a 'low pressure' connection, meaning you can't connect it directly to a grill with its own regulator.
I removed the regulator from the Q 1200 (basically removing 4 screws and replacing regulator with a gas hose fitting), and connected to the T@B using this conversion hose:
https://www.amazon.com/gp/product/B07TZKKJQG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Works great! 12' of hose means I can use the grill on either side, or behind the T@B, and no 1lb cylinders needed. I also picked up the 20lb to 1lb cylinder conversion hose, which allows you to directly connect a 20lb tank to the Q with the regulator installed...but I think I'll return that now that I know how well it works with the low pressure external connection on the T@B.
