HI, We're about to go on our first trip and was told by a person that they disconnect the electrical plug from their car when they stop at Target or the grocery store if they plan to stay for more than an hour,,,,when they are towing their T@B. We hadn't thought it would be an issue so hadn't thought about it. Thoughts? Experiences? Thanks, K
Tampa FL
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
This is like learning medical terminology and all our abbreviations! HAHA!
Thanks.
K
Odessa, Fl.
As noted by others, neither unplugging the 7pin, nor an isolation relay, will save your Tab battery, if you leave your 3-way fridge going on 12V for any period of time (been there, done that!)...
We used this one (West Marine carries it):
Rick and Barbara - North Texas
More Smiles Per Mile!
Enjoy doing and sharing mods
1. You MUST have the battery switch "ON" while towing, because if the trailer should suddenly become detached from your tow vehicle, the only power to the emergency brakes will be your trailer battery. The emergency breakaway cable on the trailer is designed to activate the emergency brakes on the trailer in that situation. When the plunger is forcibly pulled out of the switch, that creates an electrical connection (via the trailer battery) to the trailer brakes, locking them up so the trailer will stop moving forward.
2. If you are operating your refrigerator on the trailer battery while towing, and you stop for more than a brief period of time, the refrigerator will continue running and will quickly deplete your trailer battery. At least that is how it works with the three-way refrigerator. I can't speak to the the newer two-way version, but as @Sharon_is_SAM has described, it draws less power from the trailer battery.
3. The purpose of the relay switch on the tow vehicle is to prevent the tow vehicle battery from sending power to your trailer when the tow vehicle ignition switch is turned off.
Hope that helps.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I initially believed that our Tacoma (w/o any 'tow package') would output enough power to keep the 3-way fridge going. So I ran with the fridge's 12v mode on.
And I figured, for that "rare" case (sure, rare) when we'd forget to shut off the fridge at a lunch stop or whatever, I'd install an isolater, to at least save the TV battery.
It turns out however, after much trial and error, and then finally with confirmation from the Victron Battery Monitor, the Tacoma standard alternator only does a short initial high amperage charge, and then settles back to what it thinks must be what the system needs. ie: low current charging.
It probably doesn't help that due to the voltage drop between the front battery and the Tab battery, the alternator reads the voltage of the TV battery, and drops the charge rate back, when the Tab battery is still not up to level yet.
At any rate, we don't depend on the 12V mode for the 3-way fridge any more at all, though I'm still willing to experiment with solar charging while we drive.
Also on the 2 way frig the Unofficial nüCamp T@B400 Resource Guide I got from this forum lists the amp draw of the 2 way at 5.15 amps so a brief stop of even 2 hours would not deplete the trailer or the TV battery. And that is assuming it would run all the time, which it does not when already cooled down.
Thanks all
