We have a 2019 Tab 400 and I need to know if our water pump is defective. When you first turn the faucet on after the pump has reached pressure the flow is good for about 5 seconds. After that the flow reduces to just a small stream (about 1/4” diameter) that is totally inadequate to run the shower. Water literally dribbles out of the shower head once the initial pressure is lost making the shower function while boon-docking totally ineffective.
Here are a couple of pics of what I see in our sink. Just need to know if this is normal like my service dealer says it is.
If it is in fact normal, then is there a recommended replacement pump that will actually move some water?
Concord, NC
Concord, NC
We had the unit in to a local NuCamp dealer for warranty service on a few minor things of which one was the poor pump performance. Very disappointing that the tech said it was normal and we have been dealing with it since. If I can't resolve it then we will reach out to NuCamp. I have had great experience with their warranty group.
At least in our 2020, the pickup and tank drain use the same port in the fresh water tank. If you are getting good drainage from the tank, then I wouldn’t think it would be anything inside the water tank blocking the water.
Also, I am intrigued by TNOutback’s comment on the source for the siphon hose. Is there a schematic on the forum of the 2019 era 400 plumbing? Having a common source for both the drain and siphon makes sense.
Some day I am going to drop more of the bottom to get at the drain and siphon lines to completely wrap them up with some pipe insulation.
Concord, NC
If it goes away, the issue is upstream (toward the tank); if it persists, it's something downstream of the pump (toward sink/shower taps).
Jim
My biggest problem in this “warranty” repair was having to buy a PEX Clamp tool and associated elbows, fittings and pipe. Although this is much better than taking it to the dealer and waiting 3 weeks to possibly get it fixed.
Thanks to everyone for providing good information. Hopefully this is a rare occurrence for most of us.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
I wonder if they try to flush debris from the tank at the factory before adding the rest of the plumbing. It seems like there have been enough reports of this kind of issue affecting the pump or drain that they would have put some kind of preventive measures in place. If moving the output tap from the tank bottom to the side was supposed to be the fix to avoid debris plugging the lines, then it not only failed, but created new issues in the process (poor drainage & reduction of usable tank volume).
