If you want to use your T@B at home on your own property as, say, a guest bedroom, how do you connect up electricity?
I don't think any standard home wiring has plugs for 30-amp cords, so how do you run power from a standard 120-volt socket into a connection on the trailer?
Thanks in advance.
https://www.lowes.com/pd/Road-Home-12-In-RV-Electrical-Adapter-Fits-15-Amp-Male-to-30-Amp-Female-with-Pull-Out-Handles-Type-12-3-SJTW-30-Amp-125-V-to-4-Degrees-Fahrenheit-Cold-Weather-Jacket-Black-with-Yellow-Handles/1002699848?cm_mmc=shp-_-c-_-prd-_-rpe-_-google-_-lia-_-208-_-tubulardrainage-_-1002699848-_-0&store_code=86&placeholder=null&gclid=EAIaIQobChMIodal6Iuq6gIVmY7ICh3MCQffEAQYASABEgJwqfD_BwE&gclsrc=aw.ds
Others will undoubtedly chime in with more details/options...
Edit: Just remembered, an electric clothes dryer is usually a 30 AMP device
2019 320 Boondock Edge - Sold Jan 2022
The formula is pretty easy: We need to solve for current here, and current is equal to wattage divided by voltage.
We know the voltage is 120 volts.
Determining the wattage of the various devices will take a little homework, but some of the figures are available on manufacturer's spec sheets. Here's the data on the big power hogs.
Dometic lists the 10,500 BTU CoolCat used in the T@B 400 as using 1,330 watts when cooling, 1,048 when used as a heat pump.
The 5,000 BTU units in most of the 320's will use about half that, so around 650 watts.
**Note that this is operating current, and there will be a momentary spike in current draw when the compressor first starts up; normally this will not trip a breaker, but if it does, don't continue to try and use it.**
The Alde on the 1kW setting uses 900 watts; on the 2kW setting it uses 1,800 watts.
The High Point microwave in the 400 uses 1,350 watts.
So let's plug in some numbers assuming you have a 15A circuit in the garage like I do.
CoolCat: 1,330 watts divided by 120 volts = 11.08 amps - good to go on a 15A circuit.
Window-style A/C: 650 watts divided by 120 volts = 5.41 amps - also good on a 15A circuit.
Alde heat on 1kW setting: 900 watts divided by 120 volts = 7.5 amps, with plenty of room left over for the circulating pump (minimal draw).
Alde heat on 2kW setting: 1800 watts divided by 120 volts = 15 amps - so no go here; it's at the maximum before you even factor in the circulating pump or any other potential draws.
Microwave: 1,350 watts divided by 120 volts = 11.25 amps - so that'll work, but obviously not with the Alde or either style A/C on.
One thing I haven't factored in here is other devices that might be drawing current at the same time. Most devices other than the ones listed above are very low draw, but having multiple things on adds up, and current is an additive calcluation.
The lighting is LED, so minimal draw there. There's some draw all the time from the radio and TV and from the CO detector, but again, minmal. The Fantastic Fan draws around 2A at high speed. Refrigerators will vary from model to model.
A couple of other safety-related things: Put your hand on the adapter and the outlet into which it is plugged once you've run something big like the A/C for a few minutes. If it feels hot, even if the braker didn't trip, DISCONNECT IT IMMEDIATELY. If the breaker keeps tripping, DISCONNECT AND STOP USING THAT OUTLET until you can get an electrician in to asses the situation. Safety over convenience, always!
Hope this helps some.
Jim
cheers.
Tampa FL
An RV converter gets very unhappy very quickly when it's fed with 240V, and it doesn't take long for wiring to start melting.
