The bathroom door hits the ceiling in the front of the T@B when opening it. I'm assuming this is a new problem with the 2021 solid door? It seems like just a matter of time before the ceiling shows some sign of wear or damage. I installed the temporary fix shown below and have a question into NuCamp to see if they have a better idea. My interim fix is a piece of swim noodle split lengthwise but thicker pipe insulation would probably work too. Hmmm... I might have to find a different color if it stays in place very long.
(Photo edited for size.)
https://tab-rv.vanillacommunity.com/discussion/comment/137338#Comment_137338
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
managed by VE Smart Network
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
I'm liking my swim noodle foam more and more - if I can find a nice blue piece, it could be a keeper <laughing... but also partly serious>.
Other possible fixes might involve the door handle or the bottom of the door and a straight-out rubber stop on a spring, though this is not very attractive. How far is the door or handle from the kitchen cabinets?
Or maybe mount a "cleat" on the bottom edge of the door, at the hinge side, that is only one-quarter of a circle (90 degrees or less), sticks out about an inch and has a metal stop face plate mounted on the bathroom wall outside (kitchen side) so that the door "cleat" and wall stop touch. The cleat may need some rubber or soft cover to prevent a person's shin from rubbing or bumping it when at the sink.
Last thought: an L bracket mounted on the outside bathroom wall (kitchen side) at a level even with the bottom of the bathroom door. Another not very attractive "projection" fix.
Photo edited for size. Moderator
2020 Toyota Highlander
Provided it's long enough could a door stop be installed into that board above the sink? (yellow dot)
If anyone asks it's the thingamajig that controls the watchamacallit. Don't pull on it or you'll be sorry.
I didn't realize it but we're experimenting with coat hook locations and this is today's experiment and it also worked as a doorstop!
https://www.amazon.com/GGIENRUI-Magnetic-Stopper-Adhesive-Conceal/dp/B07GCGJ2HY/ref=sr_1_216?dchild=1&keywords=cabinet+magnet+bronze&qid=1595802790&s=hi&sr=1-216
self adhesive!
Ontario, Canada
