320S outback.
Just noticed this on a recent trip while hooked up to campground water. I'm was not using the shower and the shower floor is dry. Anyone had a similar issue? Maybe a leak inside the water hook up point? I am using a pressure regulator.
Tab 320s Boondock
TV: Toyota 4Runner
0 ·
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
TV: Toyota 4Runner
TV: Toyota 4Runner
TV: Toyota 4Runner
https://tab-rv.vanillacommunity.com/discussion/8617/fresh-water-leak-fixed-again/p2
I also later added an access port below that door in the wall, so I could get my arm in there easier..
https://tab-rv.vanillacommunity.com/discussion/8617/fresh-water-leak-fixed-again/p3
Looking forward to hearing that you found the source.
PS:
One other spot to check inside the toilet wall is where the toilet supply line branches off the main cold water supply water line inside the wall from where you see it to right of the toilet. I think @ScottG had a leak there once.
TV: Toyota 4Runner
I snugged up the fitting where the outside water comes in by reaching down inside the hatch behind the toilet. We'll see. If there was ever any standing water it has dried up so hard to determine where it came from. Testing now. Didn't see any issues under sink area.
TV: Toyota 4Runner
